Question about Ford 8n,9n,2n, Tractor Starter With Drive
Need a picture of 9N points so I be sure if I put it back right.
Have tried to find free download of points picture to make sure I have put it back together right. I see that this is common for us 1st timers. Any help would be great. Andy
  • 218 Answers
Hey Andy..my name is Keith..and i have 9 Ford tractors..i have 9N's,2N's and 8N's...and i dont know of any site that has the manual on it..and the maintenance manual isnt expensive..and if you are going to do your own mechanicing..you will be glad you have a manual...i hope this has helped..if not please write back
Posted on Jun 30, 2009
My 2n will not start
I would check the points for open and closing.
Jan 17, 2014 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 9N problems; Changed plugs, wires, cap, rotor, points, and ignition coil. Point gap at .015, new condensor. 6 V battery fully charged. No voltage drop to ignition coil. Results, no spark.
You might check ground. some of these units were ground positive. did you switch the posts?This would cause problems since the electrons are on the inside of the condinser.
Good luck
Joe
Feb 11, 2011 | Ford 8n,9n,2n, Tractor Starter With Drive
Not getting spark all the time after putting new
Clean the points with an emery board if this doesn't fix it roll the motor until the points are open then short them with a screwdriver if it arcs see if the coil is putting out spark if not get a new coil
Dec 01, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 9N tractor will not start
bring #1 cylinder tdc check timing mark see if its lined up,remove cap and see if you rotor is pointing to #1 on the cap,I had one a guy brought to me and some kids swaped the wires.That was all that was wrong ,I have not seen one of those engine lose there timming gears,Im sure it can happen,but very few,your fireing order is 1 2 4 3,I hope this helps you
Nov 22, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Turns over not starting changed points
Verify the point gap is set right and that you are getting a good spark. Check to see if you are getting fuel to the carb.
John
Oct 03, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
No spark for 2n tractor put on a new 12 coil changed points and condersor was runing before i burned out 6 v coil
check the resistor mounted on the back side of the dash, resistor dead no spark. you can strap it with wire to see if it fires, dont run it this way.
Jun 28, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
No spark to my ford 9n tractor
you are in the wrong place that is the battery regulator. go to the distributor and pull the cap where you see the four spark plug wires. Inside you will see a set of points and a condenser. there you should have 12 volts. Get back to me after that. donnyb60
Mar 22, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 8n,9n,2n,  Tractor Starter With Drive Logo
465 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
