Teresa, Instructions on connecting to WiFi, press options button, settings, wireless network, WiFi,WiFi settings, choose the network. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." How to connect to Wi Fi on my ALCATEL ONETOUCH Idol How to set up Wi Fi on an Alcatel One Touch Connect to Wi Fi
it depend on the operating system you installed on the laptop if its windows 7 then there is a option on bottom right corner for connections click on that a menu will appear listing the available wifi networks click on the network and enter the password to get connected also ensure that your wifi modem is turned on ..
when going wifi
you have to go to internet connections or options in the control panel and click on the LAN settings button
the wifi modem will have a security code on the back and the wifi connection area code
click on the found area code on the back of the modem then enter the security code
I had this problem at least once a month. Try these things out.
1. Make sure any WEP codes are entered EXACTLY as it is for your router.
2. Set up your router so only your PC connected to it can change any settings.
3. Turn off your PC while trying to connect via PS3 WiFi. The good ole Win update likes to download without you knowing it sometimes.
4. If all else fails, call Sony cause you may have a bad WiFi antenna or motherboard.
