Question about Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
When I press start, it just continuously beeps like the motor is trying to start, but it won't. I have turned the braker off, and unplugged it. I have pushed cancel. But it still won't start blowing and turning.
  • ketchisummer Jun 26, 2009
    Model # - Frigidair Affinity #AEQ8700FE0 (Can't tell if the O's are a letter or number; guessing numbers)
    They were purchased 2-08 but are installed in our vacation home and have only been used for 4-5 months of normal use.
    There are not any error messages displayed nor flashing lights or codes
    No error message display
    no beeping; just motor trying to run
    model #AEQ8700FE0 - Frigidair Affinity
    Age - purchased 2-08; is in our vacation home has probably been used normally for accumulative of 4-5 months at the most.
  • 15,935 Answers
I will require more information to remotely troubleshoot your problem.
Please use the "Continue With This Expert" option and reply with answers to the following....
1. Any Error Message on the display? Lights flashing, codes etc.
2. Exact model # of the Dryer
3. Approximate age of the unit.
Thanks!!
Posted on Jun 26, 2009
  • blueextc3221
    blueextc3221 Jun 26, 2009
    Well - it's unfortunate - but it appears as if your controller board has failed.
    Sometimes power surges can back feed into the board and cause damage.
    If ANY sensor or problem is found faulty - an error code will appear - (ex. F12 or DL ) Since you cannot even enter the diagnostics, the board is faulty.
    CLICK HERE for an expanded view of the controller - the controller is #1
    CLICK HERE for a replacement board.
    Thanks for using FixYa!!
My Fisher & Paykel ED56 dryer will not start.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com Kenmore Whirlpool Dryer Won Start Easy Fix
Jan 13, 2017 | Fisher Washing Machines
How can I fix my HE4 Gas dyer it will not start
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix
Jun 21, 2014 | Kenmore 659 Electric Dryer
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
I have i kitchen aid gas dryer,when i press the start button it makes noise for about 3-4 second s then it stops and it won't start
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Feb 27, 2012 | KitchenAid Dryers
The oven is GE JKP15,about 10 years old. Error: F7 - Keeps beeping. Turned on brakers, but it starts beeping again when the braker is turned on.
this code means either a stuck control pad or a faulty control board/display board... one thing to try is turn power off again at breaker and run your hand over all the keys on the control panel firmly pressing each key sometimes you can luck out and free it up if that is the problem and reset power if it starts again you will have to gain access behind the control panel and unplug the ribbon cable to control panel.... if it stops after you unplug ribbon cable most likely it is a bad touch pad assembly if it continues you most likely have a stuck relay on the control board and will need to replace that... i have see the fault require both the touch pad and control board ,but hopefully this will help you ..i assure you it is one of the 2 problems ... g.e servicer for 18 years now and a common problem most of the time happens after a long cooking period or a self clean was preformed recently...
GOOD LUCK
Feb 07, 2011 | Ovens
When I turn the dryer on the green light flashes; when I press start the machines "beeps" but doesnt start Any suggestions
Sounds like it might be stuck in a cycle, Turn off at braker box wait a few seconds an turn back on, This should lit the dryer reset and try again. Also check you owner manual for trouble shooting problems.
Oct 03, 2009 | Kenmore Dryers
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
Self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Elements wont turn off
i unplugged stove plugged it back up now its got beeping sound not like the alarm my model numberb is13351737wy
May 06, 2008 | Crosley CE35100AA Electric Kitchen Range
Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
