Question about Car Audio & Video
Want to play Ipod through an OnStar/Xm radio in my Escalade.
Are there some wiring diagrams available for an OnStar/XM radio combo in my Escalade so I can hook up my Ipod to play directly into the unit. I do have an RF modulator that I could use to do this but can't figure out the wiring.
  • 578 Answers
You need to get it wiring by a pro i wont recommend you do your self
Posted on Jun 26, 2009
I have a 2014 dodge ram pickup with xm version of sirius xm. In northern canada xm signal is horrible bit sirius works flawlessly. Is there a upgrade to switch to sirius signal without adding a stand alone...
The 2012 Dodge Caliber had a Sirius radio instead of XM - BUT - you will have to check if it has a "FAST" or a "SLOW" "BUSS SPEED" - that is very important that the radio you replace it with has the correct buss speed. Sirius will only work a little while longer as they are eventually going to phase out their overhead satellites for a geostationary satellite like XM. XM has the better sound than Sirius - if you can receive them. If you can't find a factory replacement from 2012, then BestBuy still sells a Stratus Sirius radio - and you can probably even fish-out the antenna wire that you already have for use with the plug and play add-on Status. Good luck - let me know if you have more questions.
Jul 17, 2014 | Audio Players & Recorders
Factory xm no sound
You have to make sure that your plan wiith XM hasn't expired and also find out from XM if your software from them is current in your radio.
May 31, 2014 | 2008 Cadillac Escalade Esv
I have a 2011 Honda Pilot. When I push the XM button it won't even change over to the XM radio. It is like there is no XM capability in my car. What can I do?
Often times you'll need an aftermarket integration kit to get an XM ready car radio to work. This is a two part system including the tuner to tie the subscription to and a translator to code it so the radio face will understand and display the information accurately. You can find such a kit for your car here: http://www.tss-radio.com/isimple-factory-ipod-xm-integration-for-honda-acura-vehicles-hd1.html
Nov 10, 2013 | Cars & Trucks
Xm check atenna connection
If you are getting the same "check antenna" message with two different antennas, it is likely that the tuner itself is the problem. You can get just the mini tuner here:
http://www.tss-radio.com/products/xm-mini-tuner-replacement-home-dock
As far as the two plug connection, there are adapters available. Its likely a dual fakra connection, though I don't know for sure. At any rate, this is one adapter available. (I would call to confirm)
http://www.tss-radio.com/products/sirius-dual-to-single-antenna-adapter
Jun 27, 2012 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
I can't find an xm station in the 2006 impala LS that I bought, but onstar ran the vin number of the vehicle and its telling me that's the radio is xm ready
Try www.xmradio.com This is where you can get info on activating your XM radio. It will cost you about $13 a month and an activation fee. You will need the radio's ID number. If you already know this and dont have the owners manual, stop by a dealer to get it going.
Aug 13, 2011 | 2006 Chevrolet Impala
I want to disable XM radio and OnStar on my 2005 Pontiac Grand Prix. Can I remove the fuse(s) for each Unit without harming my vehicle? Can I disconnect any wiring harnesses? Where do I find each Units...
I have disabled factory xm/onstar units from many cars with no issue. i believe the onstar/xm units are both located in the trunk of you car behind the carpet (usually labeled accordingly). If you can find the fuse dedicated to the unit you can pull that. I have found the fuse is sometimes located on the unit. If you cant find the units then you can pull out the radio and unplug them from the back (more often than not it will be the smallest harness coming out the back). A quick way to test... have your car on and pull one plug at a time... make sure, once you have located it, test you audio (some harnesses are for amplified audio systems). The only neg. effect i have seen (rarely) has been the loss of the door chime.
Apr 26, 2010 | Pontiac Grand Prix Cars & Trucks
I can t access the xm part of the radio even though the on-star works
Two parts can cause this problem. The digital radio receiver and the xm antenna which is part of the onstar antenna. You will need to take it to a dealer to have it diagnosed properly.
Dec 06, 2009 | 2007 GMC Sierra 3500
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Jul 22, 2008 | XM Radio (XMP6000)
Car Audio & Video Logo
359 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
