Question about Sony XPLOD CDX-GT200 CD Player
Installing in boat
I want to direct wire to battery. What wire is which? Red + or - and what about the yellow + or - and do i need to ground the radio for it to work?
  • brian vogl Jun 26, 2009
    Do I need to ground it?
  • 578 Answers
Join the red and yellow together if dont have no radio there before radio should power up
Posted on Jun 26, 2009
How do I wire this radio into my boat? The wires coming out of the harness are one red accessory/switch, one black ground, one yellow constant power, and a blue power antenna.
Red goes to the battery.
Since this is a boat, the yellow will go to the battery too, but I recommend you put a toggle switch on this wire, so you can turn it off and it won't drain you battery. The black wire goes to the ground on your battery. The blue wire can be used as a remote turn on for an amplifier.
Thats' It.
Aug 31, 2011 | Car Audio & Video
I am installing a stereo in my car and the previous owner cut the wires and the labels are gone. The stereo I am installing has 4 wires other than the speaker wires. They are: +Battery(Yellow), ACC (Red),...
Here you go.
Radio Side -- Car side
12v (Yellow) -- Orange/Black
ACC (Red) -- White/Black
Ground (Black) -- Black or chassis ground(bare Metal)
Pwr Ant (Blue/white) -- Pink
If your not adding and amplifier than your system remote should be used for power antenna which is the pink.
Hopefully this helps
Please Vote & Rate thx
Mar 08, 2010 | Pioneer 50W x 4 MOSFET Apple iPod...
Need wiring schematics for 2004 Subaru Outback wagon- installing after market stereo
2004 Subaru Outback Wagon Radio Stereo Wiring Diagram
Radio Battery Constant 12v+ Wire: Blue/Yellow
Radio Accessory Switched 12v+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Green
Stereo Dimmer Wire: N/A
Stereo Antenna Trigger: N/A
Stereo Amp Trigger Wire: N/A
Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Red/Yellow
Right Front Speaker Negative Wire (-): White/Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Red
Left Rear Speaker Negative Wire (-): Red/Green
Right Rear Speaker Positive Wire (+): Blue/Green
Right Rear Speaker Negative Wire (-): Red
Jan 31, 2010 | Car Audio & Video
My son and his buddy recently installed an amphlified stereo system on our center console and there is something strange going on that I can't figure out. It is a Clarion stereo with a JBL amp. The boat...
If a boat is anything like a car, the amp's negative post should not be connected to the battery, but to the ground of the boat. In a car, the entire chassis is grounded to the negative terminal, so when you run a line from the positive terminal of the battery to the positive post on the amp, and a line from the negative post on the amp to the chassis it is a complete circuit. I highly recommend placing a fuse on the positive line from the battery to the amp. Wiring this way prevents the amp from blowing up your battery, as well as prevents the battery from blowing your amp. Hope it works.
Jun 25, 2009 | JBL Boating
Radio works on tech bench, not in the boat
Yes, the yellow wire is the switched hot lead - it is typically connected in one way or another to the ignition switch. There is also a smaller gauge red wire that is connected directly to the battery (through a fuse of course). Both of these wires have to have power for the radio to work. Also the black wire has to be connected to a good ground. If all three of these wires are confirmed to be in good order (power where there should be power, ground where there should be ground and no shorts) the radio should at least power up when they are all hooked up and the ignition is on.
Jun 16, 2009 | Clarion Boating
Need a stereo wire color code for 2000 subaru outback limited
The sell a nifty little invention at Wally-World. Its called a wire harness...look for it in the auto parts section. it will wire directly to your stereo wires and then just plug & go... if your subaru wires are missing the harness on the end, its a whole different ballgame, and its gonna be fun...try this...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green
Let me know how it goes!
May 17, 2009 | 2000 Subaru Outback
DehP6700 mp restet everytime keys is turned on.
first red is ignition or acc (turns off and on with the key) yellow is constant power (always hot keeps memory) orange is illumination (lights up radio) if vehicle doesnt have a seperate illumination wire connect it to the ignition wire. now process of elimination your ground is correct because it worked with all wires to acc your acc works because u had all them connected to it and it worked your problem is in your yellow or constant/memory i suggest u test it again take piece of wire any old thing long enough will do and run the wire directly from the battery under the hood and just run it outside the car through the window and connect it directly to the yellow wire make sure u have a good connection at the battery on the positive side if u have test light or volt meter test the wire before connecting it to the radio if it works then u know there is a problem with the wire from the vehicle (fuse wrong wire bad wire ) if it doesnt work make sure ground is connected tight and that paint is cleaned of the surface where ground connects and that the yellow wire to the radio is tight in the back of the radio.
Nov 13, 2008 | Car Audio & Video
What color is what on the clip coming out of the bak of the deck.(power,ground, left/right front spkrs, etc?
Good Day,
Good Day,
Red is ignition
Yellow is constant hot (you can wire red and yellow together if you don't have a constant however the radio will loose settings each time the boat is turned off)
Black is ground
Gray wires are front right
White wires are front left
Green wires are rear right
Purple wires are rear left
Blue is power Ant
Orange is ilumm
Hope this helps
Jul 07, 2008 | Sony CDX-CA850X CD Player
Installing CDM-7836 into a Boat
Yes I can help, the blue/white wire isn't meant for that purpose. That wire is meant for an amplifier turn-on. the wire you want to use is the red that is the accessory lead. What I would recommend is finding a constant 12V to hook to the Yellow and hook the switch 12V to the red. This way your radio will retain memory. Or you can connect both the red and yellow to that switch and never turn the switch off. Simply use the on/off button on the radio. Good Luck I hope I could help.
-Andrew Hawkins
Jun 18, 2008 | Alpine CDM-7834
Panasonic CQ-C1335U CD/RADIO FOR AN AUTO
what kind of car do you have a Chevy by any chance?? Any way that red wire needs to see 12 volts in order for the radio to turn on. But this is the wire that should get power when the key is turned on NOT directly to the battery. By the way, If you wires to the battery make sure that you have a fuse no more than 6 to 10 inches away from the battery. You should no matter what make you have be able to find a constant 12 volt for the yellow wire and a ground for the black in the dash. Hit me back with year make and model and I'll let you know how to find some ignition.
Nov 27, 2007 | Car Audio & Video
Sony XPLOD CDX-GT200 CD Player Logo
112 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
