New batteries but will still not start
SOURCE: y is it not working
The camera "thinks" it's connected to a TV. We had the same problem. My wife used a bobby pin to "trick" the camera into thinking it was being disconnected from the TV by probing the pin into and out of the TV connector on the side.
SOURCE: What memory card does the Vtech kidizoom digital camera use?
Just a normal SD card buy in asda etc.
SOURCE: Vtech kidizoom camera does cannot find SD card
I had similar problem. In windows i formatted the SD card as 'FAT' rather then 'FAT32' (right click on card and select format) and that made the camera recognise it!
SOURCE: Vtech Kidizoom camera. Have changed batteries but
Don't use rechargeable batteries. Use Alkaline batteries. Rechargeables run at 1.2Volts each. Regular batteries run 1.5V. The camera wants 6V. Using rechargeables, you're shorting the camera by .8Volts. It wont turn on because it thinks the batteries are low and is protecting the pictures in memory. Use regular batteries, you'll be ok and your kid will love you again.
SOURCE: need to change the batteries
see botom of device - there are two screws, left and right, turn them and you can open.
