Question about Marantz CDR420 CD Recorder
Frozen CDR420 I am a choir teacher who is not technical at all and has not had the time to spend reading the user manual. I had the machine set up to record vocal tests where all I did was turn it on and have the kids press the flashing green play/pause button to record their vocal tests. Friday evening, I came in to try to record vocal parts for new music. I began recording then decided that I should grade the vocal tests already there so I could erase the hard drive and have lots of space to do my parts recording. I began pressing buttons to try to see how I might erase the hard drive (before grading the tests.) I'm not sure what I did but now the green play/pause button is lit but I cannot get anything to come up on the display panel above the power button. I also cannot get the green light to go off by pressing the stop button or to flash by pressing the record button. It's just frozen and I don't just want to pull the plug because there are several vocal tests on the machine that I need to grade. Help, please?!
  • SecretaryDeb Mar 31, 2008
    I want to delete old tracks on my recorder so I have room on the hard drive to record another meeting tonight.....When I press the Edit Menu button, nothing happens.....it's like it's frozen.
    Nothing happens when I hit any of the "Control Buttons (File Dir, Info, Jump, etc....)
    I've tried unplugging the machine, but it doesn't help.
If you already recorded the voices, no ploblem, unplug the power supply will not destroy the recording. and start playbak again.
Posted on Oct 10, 2008
Sophia is buy-ing party favors. She has 2.75 a person to spend for 6 people. How much can she spend on party favors. write and solve as a division problem
fixya site is for technical problems for people who want advice
if you want a grade 4 maths problem answered talk with a teacher at school
Jan 05, 2017 | Event Planning & Celebration
How do iget the material feeder to come up, it won't feed material on its own
Are you lowering the presser foot? The lever is an up/down feature on the very back of the machine behind the needle.
Are the feed dogs (the little teeth under the fabric) set on "darning?" If so, the machine will not move the fabric under the needle. There is a knob or setting somewhere on your machine for this function.
http://quilting.about.com/od/quiltingglossaryf/g/feed_dogs.htm
You should get a user's manual, if one is available, search for:
Make + Model + the word "Manual"
or contact manufacturer support
or at least spend some time watching sewing machine videos on YouTube.
Apr 11, 2016 | Sewing Machines
My needle is not lining up and down to the bobbin
Your machine is out of time. Your technical manual should have instructions on how to time it. If not a sewing machine mechanic can re-time the machine for you for a nominal cost. The problem usually stems from breaking a needle that missed its spot on the bobbin case.
Jan 28, 2015 | Brother JX2517 Sewing Machine Refurbished
How do I clean my elliptical trainer?
You will notice that dirt accumulates on both the wheels and track. First, I suggest reading you user manual. To avoid dirt build-ups, I recommend wiping the machine after each use. This is not instead of a cleaning, but will limit the time you spend cleaning the machine. If your manual is not helpful, I found a great article called "Keeping Your Elliptical Machine Clean" - this should help.
http://www.abcarticledirectory.com/Article/-Keeping-Your-Elliptical-Machine-Clean-/896160
Aug 02, 2012 | Exercise & Fitness
Can i transfer information from the recorder to my computer? marantz model cdr420.
Depends on your PC and its audio capabilities.
http://www.zzounds.com/item--MARCDR420
It has analog line I/O, and SPDIF digital I/O, and USB 2.0, allowing you to connect the CDR420 to virtually anything in the world.
Feb 10, 2011 | Marantz CDR420 CD Recorder
Marantz cdr420 recorded media stored on harddrive.played back all fine unplugged now it says no valid files when i try to burn the disc but the drive reads full.
If you are attempting to burn mp3 files as an audio CD, then that's the problem. You cannot burn audio CDs from MP3 files. You have to burn MP3 files as a data CD and not as an audio CD. See excerpt taken from page 33 in the CDR420 user guide. "Prepares CDs that can be played on standard CD players. Compact Disc Digital Audio (CDDA) uses uncompressed PCM, .wav files. The CDR420 does not convert MP3 files to PCM so MP3 files are ignored if you choose AUDIO as the CD TYPE"
May 04, 2010 | Marantz CDR420 CD Recorder
No Valid Tracks or No Song Select
Feb 14, 2010 | Marantz CDR420 CD Recorder
Need to download the recorded media to a computer.. any special step because the hd on the cdr420 isnt; pullin up??? i dont have the manual and cant find it...manual would be helpful to have too...
Hi, i have located the manual for this device. you can access it and, print it out as well if you choose. the link to your manual is below.
CLICK HERE FOR THE CDR420 USER MANUAL
Please rate and god bless:)
Apr 17, 2009 | Marantz CDR420 CD Recorder
Marantz CDR420
Simply switch the analog to digital button on the front to analog, turn off the machine and turn it back on.
Oct 09, 2007 | Marantz CDR420 CD Recorder
Marantz CDR420 CD Recorder Logo
243 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
