Question about Refrigerators
GE refrigerator leaks water under the vegetable and fruit bins
    Sergeant:
  • 163 Answers
If the refrigerator is of the frost free type, and most all are today, the unit has a defrost cycle where the compressor is shutdown and a heater comes on to melt the ice buildup on the evaporator coil. This water has to go from a drip pan under the evaporator coil down a rubberized or plastic tube to another pan at the bottom of the fridge where it evaporates. Either this hose is blocked or the opening to the hose is blocked. Find the hose (usually on the back of the unit) and run a long wire with a small piece of cloth attached to the end of the wire to get it flowing again. Your water in the veggies comes from the overflow of the upper pan into the inside of the fridge.
Posted on Jun 26, 2009
Ge profile refrigerator water under vegetable bins
Most likely defrost drain is clogged
Nov 13, 2017 | GE Refrigerators
Ice build up under vegetable and fruit bins
Pull the bins out. Just above them is a channel with a hole in the middle. Push a drinking straw in the hole to clear the drain. The water will drain away instead of dripping under the veg bins.
May 04, 2017 | Refrigerators
Where is the draining hole in a ge profile model tbx25pa refrigerator with top freezer
Underneath the cooling coil (evaporator) located in the freezer, there is a drain pan with a heater to warm it during the defrost cycle. The drain opening is probably blocked by ice or debris.
Sep 26, 2014 | GE Refrigerators
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
GE TBF17PC top freezer water under vegetable
The drain hole is inside the freezer. you have to take the back panel off to get to it and thaw/clean it out. if this drain stops up it will cause water to run down the back wall of the refrigerator down to the bottom. you can pull the refrigerator out from the wall and see the plastic tube coming from the back of the freezer.
Jul 11, 2010 | GE Refrigerators
My whirlpool is leaking water under the vegetable/fruit bins and inside the cheese/meat bin.
defrost it, remove back panel on freezer side, and unclog small hole where water collects
Feb 13, 2010 | Refrigerators
Vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
Water is collecting under fruit and vegetable bins and then leaking out onto kitchen floor.
sounds like a problem with defrost drainage system. would need model #. older GE refs had problem with rust holes in drain trough. how old is it? do you see any rust on back wall of ref? newer refs had problem with drain hole freezing shut and heat probe had to be installed to prevent it from freezing shut.
Jan 05, 2010 | GE Profile 24.7 cu. ft. Top Freezer...
Water collects in bottom of refrigerator under fruit/vegetable bins
When a fridge goes in to defrost it melts the ice on the coils in the interior of the freezer. Often times there is a drain that runs to a sliding tray under the fridge. If this is clogged you will get water building up under the bins.
Jul 10, 2009 | Refrigerators
Refrigerator has water underneath vegetable and fruit bis. It seems like an air flow situation
We found that the drainage for the defrosting was plugged. The water from the freezer drains from a hole that's on the top of the fresh food unit. There's a gutter that shunts the water to a tube that runs to a tray underneath the refrigerator. The tray was bone dry. So we unscrewed the gutter from the top of the fridge, and yes, it was plugged. Some Scrubby bubbles later, the plug was done. We reinstalled it, and now we don't have water underneath the vegetable/fruit bins.
This is for the GE TBF15DC For other models, your mileage may vary.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
235 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
