Question about Trendware TEW-432BRP Wireless Router (TEW432BRP)
Same Problem. Port frowarding not working. Very confusing.
Trying to get to a panasonic IP camera thru this router. It works thru my actiontec router no problem. The Trendnet uses Virtual server located under Access Was able to configure Private port and LAN but not sure the port they speak of is the port for my camera. IE :50001 Cant find any help on the Trendnet web site. We may just go with a different router that I no works.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
Virtual Server Name can be anything specified by you. Protocol if not sure TCP/UDP, it is better to select "*" which means both. Both public and private port has to be camera's port. Like in your case it is 50001. LAN server is the local IP address of the Camera given by your router's DHCP or a Static Private IP address Same Problem.  Port frowarding not working. Very c - f0541ce.jpg
Posted on Sep 02, 2010
My DHCP is not assigning a dynamic address to one of my seven wired devices. I've had to switch over to a stati
On the second router just plug a port cable in from your main routers port into the wan port and then be sure to change the second routers gateway and IP address to a different number. Say that your main router IP is 198.18.1.1 and for your second router IP you could use 10.10.10.1 or what ever combo you want and then you should be able to use both routers together. Is this what you are trying to do?
Linksys routers as well as all routers with DHCP enabled should be able to handle up to 255 separate IP address's for a LAN network. Is the firmware of the Linksys the latest? If not, down load the latest firmware and flash the router to update it. Or, check out third party firmwares like Tomato to flash that tired Linksys and turn it into a real router.
Apr 14, 2017 | Actiontec Verizon Fios Mi424wr Modem...
I can not access my ip Foscam FI8918W camera from internet (dyndns.org)...port forward is not clear. I have a Verizon Router Actiontec GT704WG. I am supposed to access camera...
OK let me clear port forwarding for you, your router normaly has a firewall (to block of any requests from the internet to exploit any services trough any ports) so if you want access to a resource on the LAN side (side of the router where all the devices and computers are pluged) from the WAN side (side where the ISP's modem is connected for internet) you have to open a port or multiple ports to a specific device IP address (according to device manual).
for exemple:
assuming that the camera has an IP of 192.168.1.110 and it uses port 7777 for resources, in the port forwarding section of the router you ave to open port 7777 and direct it to 192.168.1.110 (save settings and VOILA)
enjoy!
Jan 04, 2011 | Actiontec (GT704WG) Router
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
BL-C131 port forwarding.
So you've configured port forwarding on the router. Do you have any anti-virus applications installed or have your set an exclusion in Windows firewall?
Feb 01, 2010 | Panasonic BL-C131 Network Camera
I have a PanasonicKX-HCM10 camera, it works ok on network but will not work on internet ,why?
check the firewall, see if is not blocking your webcam
if you have a router, enable port forwarding for webcam
usually webcam uses TCP port 5100 for yahoo messenger
Jul 16, 2009 | Panasonic KX-HCM10 Network Camera
Need to ensure my Actiontec 704WG router has IP 50 and 51 enabled
Due to time constraints (and a lack of familiarity with forums) I went straight to Premium service and was on line within the hour. They did good work.
Mar 23, 2009 | Actiontec (GT704WGV) Router
I have a actiontec gt704wg trying to connect another router behind it .... iam not able to ...
your other router has to have the following settings:
1) it's IP must be on the same subnet as your actiontec. The subnet is the "third" number in the ip address. So if your actiontec has ip of 192.168.1.0, your other router must have IP of 192.168.1.XXX where xxx is some number other than 0.
2) the dhcp server of your other router must be turned off
3) you must run a lan cable from a lan port on the actiontec to a lan port on the other router. Note that the internet/wan ports are NOT used on either router for the purpose of daisy-chaining routers together.
Dec 07, 2008 | Actiontec GT704WG Wireless Router...
Linksys camera wvc54gc
make wsure that that port 1024 is assigned to the ip address of the camera under port forwarding, you can also try changing the remote port, try 5000 and above, if it still does not work try DMZ.
you can always check if port 1024 is open on your router by performing a port scan through the net, you can get a free port scanner on this site..
www.t1shopper.com
for the process on doing fort forwarding on your 2wire router check this link.
http://portforward.com/routers.htm
Mar 15, 2008 | 2wire 1800HG Router (RG1800HG00)
Actiontec GT701-WG doesn't recognize a DVR on the LAN
I think the screen you may be looking at is the Application layer forwarding screen, the drop down box being populated by DHCP clients, that's why it isn't seeing the DVR. The DMZ Hosting screen doesn't have a drop down box, it only requires an IP address to be entered.
Hope this helps!
-Backu
Jan 16, 2008 | Actiontec (GT704WG) Router
Trendware TEW-432BRP Wireless Router (TEW432BRP) Logo
175 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
