Question about Kenmore Dryers
90 series kenmore elect. shuts off
90 series elect. shuts off after approx. 10 min. vent is clear. only does this on high-cotton setting. seems to work ok on normal. any ideas?
  • 351 Answers
Are u sure it does this only in that cycle? if so the only thing i can think of is a timer, inless the thermostat is shutting it down because the element is getting too hot.... whirlpoolpartssurplus.com mark ... give me a call free
Posted on Jun 26, 2009
I have a kenmore 90 series dryer model 110.60922990. It makes a funny noise while running for a few min. After about 10-15 min it shuts off and will not restart immediately, I have to wait for a few min...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 06, 2011 | Kenmore Dryers
If you set the dryer ( kenmore 80 series ) for 50min. it shuts off with about 20 min. left.
disconnect vent hose run dryer, sounds like the vent hose has a restriction
Jan 14, 2011 | Kenmore Dryers
I have a Kenmore Elite washer, Model 110.20096993, it starts beeping with about 10 mins left in the cycle and shuts off. Any thoughts?
I have the same model - it displays 10 minutes and keeps beeping in series of 3 (beep beep beep...... beep beep beep... etc..) ran through a cycle successfully but kept beeping like that the whole time. I unplugged it for 10 minutes but had the same symptoms after plugging it back in. I unplugged it for 24 hours, and that seems to have cleared the problem up.
Jun 12, 2010 | Kenmore Washing Machines
Need help with gas dryer Kenmore 90 series serial
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
May 14, 2010 | Kenmore 73952 Gas Dryer
Kenmore 90 series dryer leaves clothes damp. The dryer gets hot, but after almost 2 hours a large load is still damp. Happens on both auto sensing & timed dry. Checked insides & all is clear -...
Sounds like a venting problem at the house pipe.
Make sure the house venting pipe is completely clean and vent hood just outside is free of any blockages.
If all that is cleaned I would check all working thermostats and high limit thermostat as well.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
90 series dryer won't stay on
UNplug the dryer, pull it out from the wall, and remove the service panel. Use a flashlight and look around for signs of anything having burned, and smell around to see if you can identify what might be burning if you can not visually see any burning.
If you plug the unit back in while your back there, have someone start the dryer and see if you can see what might be the problem.
I am suspect the motor may be failing, but it's hard to see what's happening through these teeny-tiny little wires.
Reply back what you seeing and we can help you further.
Feb 15, 2009 | Kenmore 62602 Electric Dryer
Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Jan 09, 2009 | Kenmore 62802 Electric Dryer
Kenmore Dryer 90 Series shutting down. overheat?
Your motor is very likely overheating and needs replacement. A simple test is the motor will be so hot you cannot even touch it. Hope this helps!
Jan 05, 2009 | Kenmore 62602 Electric Dryer
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Dryers Logo
100 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
