Question about Yamaha YST-M8 Computer Speakers
Input cable Can you tell me what kind of input cable i need for my yst-m8?Look's like 8th in.jack to rca but,the RCA is black.Like it's plastic.Is it 8th in. allso? Eric.
  • Eric666 Nov 05, 2007
    Thank's
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hi Eric, you can use Black Color Cable (1.8 m) with 3.5 mm Stereo Mini Jack x 1 pc,
1.8 m (6 ft.) Cable with RCA Pin Jack, and 8-pcs No Skid Pads or you contac support for your particular speakers, considering is a good brand, here, http://www.yamaha.co.jp/english/product/av/products/pc/m8.html
there you may found your cable.
Carl
Posted on Nov 06, 2007
How do i make this woofer work with my polroid tv
OK, it looks from what I can tell you need a 1/4" stereo plug for the input to your speaker system. The output from the TV is either RCA jacks or maybe a 1/8" sub mini stereo jack. You can likely go to Radio Shack or an audio store and purchase a cable that has the 1/4" stereo plug on one end and a 1/8" sub mini stereo plug on the other. That cable would mute the TV internal speaker or if you do not want to mute the TV speakers you can get a cable with the 1/4" stereo plug on one end and the L and R audio, RCA (phono) plugs on the other. That would give you both. RCA plug and 1/4" plugs are pretty easy to install if can not find the correct cables. Good Luck. The Yamaha unit looks to be self powered so impedance matching or load on the TV audio amps should not be a problem.
Sep 02, 2012 | Yamaha YST-SW012 Subwoofer
How do I hook up my ipod to my pioneer vsx d409 ?
The best way is to use a 3,5mm stereo jack to 2 RCA cable like this:
You can easily find one like this at your local audio/electronics shop or buy one on line. You have to connect the RCA at any free stereo input at the back of your Pioneer (like aux or cd). Take a look at this picture:
After this you can use the 3.5mm stereo jack for connecting not only your ipod but every mp3 player or other device has an earphone jack. Just plug the 3.5mm jack at the earphone jack and rise the volume at the portable device up to the middle of the volume range and set your Pioneer input selector at the stereo input that you connect the 2 RCA before (aux or cd)
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 13, 2011 | Pioneer VSX-D409
Got cox Digital cable box today, cox can not tell me how to hook up to box to make it rec/play. Info I read old cox papers from 2002 says I need a vcr controller, Cox does not know what that is and it...
For a standard VCR which is what most people have, all you need to do is connect a yellow RCA cable for video from the yellow output jack on the cable box rear panel to the VCR's yellow video input jack on its rear panel. Next connect a white RCA audio cable from the cable box white RCA output jack to the VCRs white RCA audio input jack. You can record a cable show by selecting the LINE input on the VCR and selecting the TV show on the cable box.
Now for playback, connect the VCR to your TV. Connect a yellow video cable from the VCR's yellow output jack to the TV's yellow video input jack. Same for the white audio connection. Select on the TV, the source input for the VCR. Its not complicated and you should not need any other devices for a standard setup with a digital cable box and vcr.
Aug 25, 2010 | Toshiba Televison & Video
Lost the wire that goes from the control speaker cube of my yst-ms50 to the computer audio output. Were can I get a replacement wire? What should I ask for?
you should be able to get a replacement at any computer or electronics store (best buy, radio shack etc.) -
just tell them what you told us - one end (the one going to the speaker) is probably an rca jack while the other (going to the computer) is a standard audio input (3.5mm plug)
Apr 22, 2009 | Yamaha YST-MS50 Computer Speakers
Need a hookup diagram for yamaha rx-v461 plus yamaha yst-sw216 please
Here you can find the manual for your subwoofer. Looking at its back side, it has 2 RCA plug input for stereo. Receiver has just mono sub output, but as low frequencies are not easily locatable, mono is perfectly OK.
Just connect receiver SUB-OUTPUT with RCA cable to your subwoofer's RCA LEFT input. Then adjust volume to match rest of your speakers.
Feb 21, 2009 | Yamaha RX-V461 AV Receiver
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
RCA Jacks
yes..those small ports, usually color coded for input output and microphone are in fact, RCA jacks..
your user guide will tell you which are which
Nov 21, 2008 | Acer Aspire™ T180 PC Desktop
Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
Aug 14, 2008 | Televison & Video
I want to setup my logitech x540 surround sound through my tv (which is LG 37LC2D the jacks at the back are Inputs: AV In 1 RF In Y AV In 1 S-Video In 1 Scart Jacks 3 Component in Audio 1 Digital Audio...
Based on your query "...which jack...put the green cable ...", I would suggest that you replace that green cable with a 3.5mm Stereo Phone Male to Twin RCA Male as shown below.
19ba6b8.jpg. The stereo phone would match the green INput ((Front) of the Logitech X-540 while the twin RCA (white & red) would match the RCA AUDIO OUTput of the LG 37LC2D.
Of course hooking it up this way would not fully utilize the 5.1 features of the X-540 (Rear and Sub/Center) but the TV sound will come out of the front speakers.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 09, 2008 | Televison & Video
Yamaha YST-M8 Computer Speakers Logo
182 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
