Question about Maytag Atlantis MAV6000 Top Load Washer
Leaks from bottom when emptying. most is going thru tube
  • 686 Answers
Change water pump
Posted on Jun 26, 2009
I have just installed my intex portable hot tub but there seems to be a leak coming from the bottom.
That's unfortunate. Well, empty the hot tub, and then check the place thoroughly. Is it leaking from inside the outlet? Than check the plug in the outlet tube, if it fits correctly.
Detecting Leak in an Blow Up Hot Tub
Apr 01, 2017 | Pool & Spa
Oil leak
try to check if there are leaks or holes on the oil tubing located inside your car engine.. You may also check at the bottom of your car if there are leaks then repair it thru your car dealer for inspection
Nov 09, 2011 | 2007 Mercedes-Benz S550 Sedan
Water has collected and frozen at the bottom of the freezer compartment. From time to time I get small leaks on the floor beneath.
There is a drain tube from freezer/fridge and stops under the fridge and allows water to drip into an evaporator tray. The drain tube/hose can get blocked up, it is very common. Free up the tube and you will be good to go. Sometimes just snipping on the very bottom to make a larger drain hole works too.
Feb 05, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
My frigidaire refrigerator is leaking from the bottom of the freezer compartment.
usually the most common problem is the drain tube is plugged. This tube runs from the bottom of he fzr thru the fridge compartment to the underside of the fidge to a drain pan. First try to blow air from the bottom of the line. Second ck where the drain enters the Fridge from the freezer this is a very common area for this problem. good luck
Aug 13, 2010 | Frigidaire Refrigerators
There is a leak at the front of refrig clear water and all water lines have no holes and only happens in summer time
Just fixed mine w/the same problem! Unplug the fridge and pull it away from the wall. Check that your drain hose is not clogged: it runs down the back of your fridge and you need to disconnect the tubing from the fixture where it goes into the middle of the back of the fridge, by turning the fixture approx. 1/4 turn counterclockwise. This will help disconnect the tubing and will allow you to pull out the fixture which connects to the internal drain. I had to run a pipe cleaner and hot water thru this fixture, which has several S-curves in it that traps sediment. Check the tubing too. If these aren't clogged, your internal drain may be iced over. You will have to empty the contents of your freezer, and remove the icemaker and back panel of the freezer (my screws were 1/4-inch ratchet type). There is a drain hole at the middle bottom of the back wall. Check for ice and pour in very hot water to melt it. Check the inside of the bottom part of your fridge to make sure water isn't leaking in from the cooling vents at the control panel. If neither of these tasks works, then I don't know what to tell you! Good luck!
Jul 19, 2010 | GE J Series 20.6 cu. ft. Top Freezer...
Water leaks from bottom when put i put the water in tank
There are two possibilities:
1) Are you possibly overfilling? There is a small indentation at the back of the reservoir where the water can escape if you fill too much. It's easy to spot.
2) If you're definitely not overfilling, only other possibility is the thin plastic/rubber tube inside the machine that takes the water from the bottom of the reservoir, past the heater plate, to the top of the filter where it's supposed to drip down thru the coffee. Sometimes this tube perishes from heat/age and starts to leak.
WARNING - there is a lot of electicity and circuitry down at the bottom part of the KM7000/KM7005. If you have a leaky wayer tube, best stop using the rig completely. You don't want some of that leaking water to touch the live parts inside the rig :)
Jan 03, 2010 | Krups KM7000
Leak from bottom of fridge
Two things might be happening. One is the line to the fridge is leaking, this line come thru the floor or wall to the bottom and hooks up to a water valve, it may just need tightening. The other problem is you will have a hose that runs from the filter down in behind the crisper drawers to the bottom and coils up here to hold water for cold use. it then runs thru the bottom pan out to the front, to the bottom door hinge on the freezer side up the door to the dispencer. Check along the hose for a pin hole look at the bottom hinge area first, things bump into it here and can damage the plastic cover.
Jul 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water goes in reservoir, not thru hose to sump pump, leaking
blow some air thru the discharge line,, thats all it is the line is clogged, if the pan is filling with water, it is working but they do get clogged with dust and lint in the air,,
Jun 11, 2009 | Maytag M3DH30B2A Dehumidifier
Water leaking from freezer
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from comming out the freezer door and leaking onto your floor and running down your copper pipe to the basement.
May 12, 2009 | Hotpoint HSS25GFP Side by Side...
Maytag Atlantis MAV6000 Top Load Washer Logo
69 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
