Question about HP Computers & Internet
Hp pavillon dv9000 error beeps
1 long and 2 short beeps
Now video? All the lights are on? Tree beep codes? A long one followed by two shorte once? Found solution, at least with my two HP dv9000 series laptops. The video chip on the bottom side of motherboard needs to be re-flowed. The best way to check it is to apply decent pressure on the left side of keyboard until you feel that you’ve pressed the motherboard against the bottom side of laptop. Good for couple start ups unless you hit it hard J. If it works, find a manual on HP site how to take your laptop apart and use this video how to re-flow motherboard.
http://www.youtube.com/watch?v=vR8L3B3eDr0
Posted on Aug 13, 2009
  • HP Master
  • 32,281 Answers
Depending upon your BIOS manufacturer, generally this POST error code means either a video problem or a motherboard problem. The video card on a laptop may not have its own RAM and it uses part of the main memory. Reseat the RAM module/s and id this doesn't work get the RAM module/s tested in another laptop or at your friendly computer shop.
If the RAM is OK then you have a motherboard problem, and this may not be cost effective to fix. Consider putting your money towards a new laptop, remove the hard disk and put it into an external USB adapter case and use it as an USB hard drive for backup etc.
Posted on Jun 26, 2009
Beeping on start up
The following beep codes are common to many HP and Compaq desktop computers. Use these codes before referring to the other codes when they occur.
Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occurwhile restoring, flashing or updating the BIOS :
Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
You can refer to the link mentioned below for further troubleshooting:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=bph07107#N589
GuruAid
Apr 09, 2014 | HP Compaq Presario SR1830NX PC Desktop
Dv9000 1 long and 2 short
see my thread here about beep codes :
http://www.fixya.com/support/r15891519-bios_beep_codes
hope it helps
Jan 14, 2013 | HP Pavilion dv9000 Motherboard
HP DV9000 blank screen 1 long and 2 short beeps at start up
This is a indicator of motherboard failure, first! remove one stick of ram memory and try again, if no! remove second piece and put back the first and power up, if no result! the motherboard has major issues and will need to be replaced, or new laptop.
Apr 22, 2012 | HP Hewlett Packard Pavilion DV9000Z 17"...
Hp pavillon dv9000 soun problem
Very sad to tell you that this is a very know issue with the HPs running on dv9000. The things you can do as a simple steps is to restore your computer to an earlier date it your issue occurred very recently.
Else what you can try is to update your BIOS with the latest upgrade from HP website
Upgrade your audio / sound card drivers with the latest versions available.
Note :- Even HP hasnt come up yet with a permanent fix for the problem I guess.
If you need suitable assistance you can also get online technical support. I would suggest you to contact TheBestPcDoctor. I get my issues fixed by them.If you need you may also contact them @
www.thebestpcdoctor.com or via 877-407-9229
Please Rate if you find it useful
Oct 06, 2011 | HP Computers & Internet
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
Turns on but will not load anything?
Assuming you mean turns on as in powers up but not loading OS...
Whenit boots press F8 or F2 for safe boot and then choose safe boot... see if the machine stops at CRCDISK.SYS. If so you will need to do a rescue of the disk if possible...reloading the OS. If that fails the DV9000 series has a known issue with NVIDIA video drivers and a google search on the two together DV9000 and NVIDIA problem will give you all kinds of info on the issue. There is a class action lawsuit in relation to the error on NVIDIA because it is a non-recoverable error. Final option is a BIOS error and to flash teh BIOS you need to be able to get into the Operating System. If the system is beeping or flashing the LED lights (power, battery, etc) during start up. This is the computers own code and dependent on the flash/beeps youwill be able to diagnose better. So listen for two short and one long, etc.
Jun 06, 2010 | HP Pavilion dv9000z Notebook
HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Jan 19, 2009 | HP (5185-6477) Motherboard
Computer beeps when I try to start up
No Beeps
No Power, Loose Card, or Short.
1 Short Beep
Normal POST, computer is ok.
2 Short Beep
POST error, review screen for error code.
Continuous Beep
Repeating Short Beep
One Long and one Short Beep
Motherboard issue.
One Long and Two Short Beeps
Video (Mono/CGA Display Circuitry) issue.
One Long and Three Short Beeps.
Video (EGA) Display Circuitry.
Three Long Beeps
Keyboard / Keyboard card error.
One Beep, Blank or Incorrect Display
Video Display Circuitry.
Jan 05, 2009 | HP Computers & Internet
DV9000Z beep codes
1 long, 2 short on the HP DV9000 is "bad video adapter". Since your video card is integrated into your motherboard, you're looking at replacing the entire board (between $200-$400 on average) + labor costs. It would be more cost effective to purchase a new laptop for $100-$200 more, with full warranty.
Hope this helps, and remember to rate those that offer free help :)
Sep 28, 2008 | HP Hewlett Packard Pavilion DV9000Z 17"...
Computers & Internet Logo
3,285 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
