Question about Husqvarna 23 Hp 48" Deck Yard Tractor
What will make the mower blades just stop while moweing and not come back on ?
  • 10,865 Answers
Your deck is activated by a vacuum system under the hood of the tractor. there are two fuses involved and other components. I would begin by checking the fuses, in the fuse panel under the dash panel.
Posted on Jun 26, 2009
  • Joe Hogan Jun 26, 2009
    your deck is activated by a vacuum system under the hood of the tractor. there are two fuses involved and other components. I would begin by checking the fuses, in the fuse panel under the dash panel.
I was mowing with a timecutter 4200 the blades stopped and won't restart what do i do
check fuses and then start testing the wiring and clutch
Sep 12, 2014 | Garden
Why would blades just stop when mowing with ex mark lazer Z (model lz25kc604) I had beeing mowing for about 6 hours. Then it just stopped
It sound like the PTO clutch has died.
Test your PTO clutch. It should have a resistance of 1.7 to 2.5 ohms.
Jul 27, 2014 | Garden
We have a John deere 314 lawn mower. After you mow a few minutes there is a loud pop and the mower stops running. After it sets just a few minutes it will start right back and mow a few more minutes and...
Julie this sounds silly but try and run it with the exhaust and muffler removed. If it ticks over and then stops when it's engaged for a few minutes it sounds like its suffocating.
Sep 07, 2013 | Garden
Mower blades stops running
check bearings in the spindles and check belt tensions.
Jun 15, 2013 | John Deere Garden
Bolens st160 hydro eliminator 16hp tilling transmission .took the blades off 2 sharpen,1ata time,installed them, probably not in exactly the same position.started mowing the mower mows about a foot then...
Make sure the shape edge of the blades is installed closer to the ground. I don't think it matters what the position of the blade is.
Gary
Apr 25, 2011 | Garden
Troy bilt mower self propelled 21". Belt has come off
Take the three screws out of the belt cover. One screw in behind each back wheel. The other is under the mower near the shaft to blade. Remove the tension spring off the transmission. Then remove blade and the cover comes off. You then can put the belt back on. Sounds like fun don't it!
Jun 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Riding mower Safety Tips
Lawn mowers in general can be dangerous, but riding mowers and lawn tractors are even more so. Some models have better safety features than others. You’ll want to look for, at the very least: * A system that prevents the engine from starting unless the blade is disengaged and the machine is in neutral. * An automatic blade shut-off that stops the mowing blades if you stand up rather than sit on the machine, or if you leave the mower/tractor. * A system that stops the blade if you shift into reverse, or at least a lock that requires you to make a deliberate decision to mow in reverse.
Aug 27, 2008 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
104 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
