Question about Vodavi 30-Button XTS Telephone
Alarm displayed on phone
My phone display shows Alarm:- ,Blue ,Red, , , What is this and how do we fix it?
Re: Alarm displayed on phone
This indicates there was a problem with your T1 line. Pressing 606 will clear the message on the phone. If the message returns, you may want to have your T1 line checked.
Posted on Jan 11, 2008
0 characters
3 Points
How to fix a phon display
The only solution is to replace the display with new one
Oct 14, 2014 | Phones
My phone display shows the message: Warning! Major Alarm. Is my phone no good, do I need to replace it?
The major alarm is a message sent for the system to the admin phone. it can be anything from a power reset to a clocking issue with the CPU card.To reset the warning press the Spcl button then 019.Keep an eye on the warning codes to see if it re-appears.
Sep 17, 2010 | Inter-Tel 662.3800 24 button Standard GMX...
My red message indicator light is on, but i dont have any messages. How do i fix this? Panasonic KX-DT343
Press the MESSAGE button and look at the display. The red message light is lit from any phone pressing the MESSAGE button when they call you or (a Pana whoops) dialing 4 into the busy tone.
One of the soft keys under the display will be CLEAR. That clears the message from that phone.
Jul 29, 2010 | Panasonic KXDT343 Phone
Show telephone's own ext. number
To find out what the extension is in the board room,on the board room phone press feature *0 then press one of the intercom keys. You could also call another extension from the board room phone and see what extension number is on the display of the phone being called.
May 26, 2010 | NorStar T7316 Corded Phone
Panasonic KX-TG8423E Time & date display issue...
Same thing happened to me on one of the phones but if you go into display setup you can choose the wallpaper with time and date showing or without. You need to choose the - with time showing on each phone individually.
Jan 10, 2010 | Panasonic Phones
Making the date and time show after the phone rings.
Sounds like you have several issues here...Time & date is set by entering the DB Administrator, then using the code 08-14. Feature69 defaults a set, not the time. The incoming display is normal, as you are a member of the first UCD group. When you pick up the phone, it shows ICM because you are in intercom mode. There are 3 different ITCM modes: green, red, blank. Your extension button lights red because it's an indicator that you are on the phone.
Jan 16, 2009 | Comdial 8324S-PT Corded Phone
How to turn on the alarm and turn it off
To enable the alarm, push and hold either alarm 1 or alarm 2 button on left side of face... eventually it will switch the display and say alarm enabled and you can then push the alarm button to switch between buzzer / radio / off.
Nov 18, 2008 | GE 2.4GHz Cordless Bedroom Phone
Display always shows "Message for you"
Phone company should be able to fix this. Generally if you don't have the code to enter the phones system, you won't be able to clear it.
Nov 07, 2008 | NorStar M7208 Corded Phone
Main line shows solid red light
Fast fix is to turn off the power on the cabinet and power it back up.
Sep 08, 2008 | Panasonic KX-T7633 Corded Phone
Vodavi 30-Button XTS Telephone Logo
191 people viewed this question
Top Vodavi Phones Experts
Mark Taylor
Mark Taylor
Are you a Vodavi Phone Expert? Answer questions, earn points and help others
