Question about Yamaha HTR-5740 Receiver
HTR-5740 Receiver Subwoofer Problem
I have a Yamaha HTR-5740 Receiver Well it has the subwoofer that comes with it, witch works perfect, But I have other subs that require regular speaker wire, is it possible to hook up these subs to the receiver? Thank You
  • ChristianLee Jun 26, 2009
    well theres places for speaker out in the receiver but non for subwoofer, and the subwoofer itself dont have outputs on it, just the normal aux cable, is it possible to split one of those aux cables for speaker wire?
  • 578 Answers
As long as there is a speaker out from the receiver you should be ok just make sure polarity for spkr is right --remember you workng with AC current bad wire will cause fire==
Posted on Jun 26, 2009
Cant get my subwoofer to turn on that is connected to my yamaha receiver
MAke sure you have the lfe output enabled. Or you could try to use a headphone to rca adapter from a cd player/phone to test it directly.
Feb 21, 2013 | Klipsch Audio Players & Recorders
HOW TO HOOK UP SDAT 8
You need a long enough subwoofer cable ( Male connectors on each end ) and connect it to the female RCA input on the sub and the rear of your receiver has an output labeled subwoofer out connect the other end of the cable there and you are good to go. Make sure both the receiver and the subwoofer are powered off when making the connections.
Feb 15, 2012 | Yamaha Audio Players & Recorders
There is no sound coming out of the subwoofer
I assume it's an active subwoofer, since it hums. Did you activate sub in the receiver menu? Did you turn up the volume on the sub?
Jul 08, 2010 | Yamaha HTR-5840 Receiver
Humming coming from the speakers
From all speakers?
How is the audio connected to the TV (be specific)?
Keep in mind that a TV is not generally an audio source as its programming always comes from something higher up the audio food chain than itself. Get the audio to your receiver from whatever THAT is, not the TV.
May 29, 2010 | Yamaha HTR-5730 Receiver
Problem with a subwoofer output..
Check your settings in the Receiver Main Menu. Go to Speaker settings, then to Subwoofer, and select "Yes" or "On" or it may say "LFE or Both" choose "Both" Hope this helps. If you still have a problem, post a comment and I can help you some more
Aug 11, 2009 | Yamaha HTR-5730 Receiver
HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
Jun 26, 2009 | Yamaha HTR-5740 Receiver
Want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Feb 03, 2009 | Yamaha HTR-5940 Receiver
Yamaha HTR-5240 no sound from main speakers
check and see if there is a a/b,a+b setting for speakers make sure its set to a
Jan 06, 2008 | Yamaha HTR-5240 Receiver
Connecting a Yamaha VX7 Subwoofer on my Yamaha HTR 5730 AV Receiver
Hello srqwrk,
You can connect the VX7 to the 5730 using an RCA Y cable like the one shown in the picture below. You get your one connection for the receiver and 2 for the VX7. These are available at any electronics store. Remember that the cable should be long enough to go from the receiver to where subwoofer will be placed.
Hope this helps. Let me know.
cancerags
Nov 26, 2007 | Yamaha HTR-5730 Receiver
Yamaha HTR-5740 Receiver Logo
281 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
