Question about Weather King 10AJA3601AH Air Conditioner
Ac works but when cut it off blower comtinues to work inside house-will cut off with the braker switch on it but turn it back on and it comes on even when air is set on off. Please HELPPPPPPPP!
  • 614 Answers
You have a bad fan booard or fan relay. Get service tech to change. Some things you cant do yourself. To many fan boards are out there. Fan relays are pretty common. Goodman units have a fan sequencer. Carrier Brynats and and others have fan boards. get a quote befor you commit. That way you know how much it will cost. Rus
Posted on Jun 26, 2009
There was a burning odor that emanated from the air ducts, now blower is opperable
Posted on May 09, 2011
Why does my air conditioning on my 2009 Pontiac torrent turn itself off?
Was the air flow ok before it stopped working ?
Following could be additional possibilities :
1. Bad blower motor
2. Choked evaporator coil
2nd one seems a primary issue ... if evaporator coil is choked it will flow less air in the cabin and after coil reaches the set temperature the thermocouple sensor will cut off the AC (that might be what has been happening so far) .Now ,You should be hearing the sound of blower but no air from the vents.
Sep 06, 2015 | 2009 Pontiac Torrent
AC Heater
It sound like the blower wheel of the blower motor is rubbing the inside of the housing (the smoke). Sounds like the blower wheel rubbing may have burned the inner plastic housing or has come off of the motor shaft inside. Take the blower motor and wheel back out and inspect everything closely I think you will find the problem.
Apr 13, 2014 | 2004 Ford F-250 Super Duty
I turned on the ac and the light does not work, the vents are not blowing and the car is running hot. I have a saturn SL 1996
First check the 15 amp HVAC fuse located in the main fuse block inside the car on the passenger side of the center console, under a cover. If the fuse is good, then the problem may either be the HVAC blower switch (which is the fan blower selector switch), the fan blower motor resistor, or the fan blower motor. An auto repair manual will explain and illustrate for you the steps on how to check each of these components.
Even after pushing the ac light switch on, the fan blower selector switch has to be turned on as well (working) because it provides an electrical path to the positive side of the battery to complete the circuit and turn the ac light on. What the ac light switch does is provide the electrical path for the ac compressor clutch to come on through the ac control relay which is controlled by the car's PCM(computer) when you want ac, but the ac light switch still needs to run through the fan blower selector switch to receive its power. You can turn on the fan without the ac light switch because it gets its ground path(negative) from the blower motor. So the blower motor has to work in order to provide a ground path for the fan blower selector switch to be functional. You could have a faulty blower motor which is why no air blows through the vents. The fan blower motor is located inside the car on the passenger side underneath the dash at the bottom end of the glove compartment box. You'll see it. It's right above where a person rests their feet on the floor. Therefore, if your 15 amp HVAC fuse is good, check to see if you have voltage at the blower motor connector. Unclip the connector and with the ignition on and the fan blower switch moved to any one of the first 3 selections, check for voltage using a multimeter. The voltage will vary because there is a blower motor resistor. Voltage should be higher on setting 3 than 1. If you do have voltage at the blower motor connector, check for a faulty blower motor. The auto repair manual will tell you how to do it using jumper wires.
It's normal that your car is running hot because the radiator fan works in conjunction with your ac compressor. If the ac is on, the radiator fan will be on and therefore the engine coolant temperature will stay in it's normal operating range. If the ac is off, the radiator fan will stay off as well and the engine coolant temperature gauge will begin to rise and show pretty hot (especially at idle). It will do this up until a certain degree then the radiator fan should turn on thermostatically and stabilize the temperature. It's scary and I know what your saying because it does that to my car if my ac isn't on. Don't worry it won't overheat.
May 29, 2011 | 1996 Saturn SL
Fridge wont get cold
Check your brakers, on your house braker panel, it should be a 20 amp, pust it all the way off, then all the way on to reset
Jul 04, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Heater Blower won't work
Find the blower motor on the passenger side just above where the passengers feet would be. You may need to remove a panel (fairly easy). You will see a round metal housing about 4" in diameter. Turn on the ignition key and blower motor. Then tap the housing with a small hammer or a screwdriver. If the blower comes on.....replace the motor. If not, find the wires leading to that motor, undo the connector and check for power and ground in them.(You did check fuses first...right?)
Oct 28, 2009 | 1995 Chevrolet Suburban
Blower for ac/heat only work on lower 3 levels.
Check the blower motor resitor. Use a 12v test light at the switch and notice the bulb brightness change as you switch settings.. Probably have a bad blower resiter.
Jul 07, 2009 | Chevrolet Blazer Cars & Trucks
AC unit turns on blower doesn't come on
The thermostat is the controller.
Jun 19, 2009 | Heating & Cooling
Honeywell CT3600-AC not working
could be froze up if it is turn it off to melt ice clean unit could be low on freon or bad blower motor
Jun 17, 2009 | Honeywell CT3600 7 Day Electronic...
2003 AC unit problems
there is a resistor block in the blower housing, it could have been damaged when the field mouse nested on the blower.
it is coils of wire ( nichrome wires) with 4 wires connected to a socket . this slows down the speed of the motor.
tnx 4 using fixya,
drcool
Sep 17, 2008 | 2003 Mitsubishi Lancer
Air conditioner not working
the outside condesor unit is not coming on for a number of possible reasons. First check your breakers for a tripped breaker, even if they appear on, turn the ac breakers off and then turn them back on. if after this, turn on the thermostat, outside you should here the contact switch on the condensor unit humming. if still no power, check for any breaks on your wires going in from the house, still nothing give a call back
Jun 24, 2008 | Ruud UAKA030 Air Conditioner
Weather King 10AJA3601AH Air Conditioner Logo
128 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
