Question about Maytag Neptune MAH5500B Front Load Washer
Need to install LP converion kit How do I get to the inside of dryer
How to take the neptune case off to install a LP kit?
    Problem Solver:
  • 12 Answers
To convert a gas dryer to lpg. Undo door hinge screws, lift door and hinges, door should come off. opposite side of door opening remove 2 screws opposite form door hing side. Now the front panel will pull off front the top. Ease the top out and the bottom is just sat in two hooks and will lift out. Now your are in.
Posted on Nov 07, 2007
Gas conversion lp kit 8927 has 2 pilot orifices...I only need 1, correct?
The smallest pilot orifice is used for LP. Make sure you read the instructions thoroughly. Usually the gas valve pressure regulator is disabled and the burner orifices are also changed. Good luck and hope this helps.
Aug 11, 2014 | Williams Wall Heaters: 30,000 Btu/hr...
Tip
Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom
Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom Lens + 16GB Memory Card + LP-E8 Battery + Case + Accessory Kit Reviews
Other products by Canon Ratting Out of 5.0 Special Offer Total New 1 Total Use 0
Read More From Here Now
Kit includes:
♦ 1) Canon EOS Rebel T2i Digital SLR Camera
♦ 2) Tamron 28-80mm Zoom Lens
♦ 3) Tamron 70-300mm Di LD Macro Zoom Lens
♦ 4) Transcend 16GB SecureDigital (SDHC) Card
♦ 5) Precision Design 1000 Deluxe SLR Pro Carrying Case
♦ 6) Spare LP-E8 High-Capacity Lithium-Ion Battery Pack
♦ 7) Precision Design USB 2.0 SD/SDHC Card Reader
♦ 8) Image Recall Digital Image Recovery Software
♦ 9) Precision Design Memory Card Storage Wallet
♦ 10) Precision Design Deluxe 6-Piece Cleaning Kit
The Canon EOS Rebel T2i features a class-leading 18.0 Megapixel Image Sensor and increased light sensitivity for low light photography, as well as an advanced HD Movie mode for gorgeous Full HD movies. Able to capture up to 3.7 frames per second, it's ready to go the minute it's picked up. Advanced Live View, a new wide-area screen, plus features like Canon's brilliant Auto Lighting Optimizer and Highlight Tone ensure brilliant photos and movies.
This set of Tamron lenses includes a 28-80mm standard zoom lens, and a 70-300mm Di LD macro zoom lens.
Take more high-resolution pictures faster with this 16GB High-Capacity SecureDigital (SDHC) memory card.
Increase your shooting capacity with this powerful LP-E8 Lithium-ion rechargeable battery.
Made from durable nylon, and outfitted with a leather reinforced handle, this multi-compartment case will easily hold your camera, lenses, flash, and accessories.
Transfer files quickly and easily with this convenient USB 2.0 SecureDigital (SD) Card Reader.
Retrieve lost or deleted images from your memory card with Image Recall Digital Image Recovery Software.
Keep multiple memory cards protected and organized with this durable storage wallet.
Technical Details - KIT INCLUDES 10 PRODUCTS -- All Brand New Items with all Manufacturer-supplied Accessories + Full USA Warranties:
- <#1> Canon EOS Rebel T2i Digital SLR Camera PLUS + <#2> Tamron 28-80mm Zoom Lens + <#3> Tamron 70-300mm Di LD Macro Zoom Lens +
- <#4> Transcend 16GB High-Capacity SecureDigital (SDHC) Card + <#5> Precision Design 1000 Deluxe SLR Pro Carrying Case +
- <#6> Spare LP-E8 High-Capacity Lithium-Ion Battery Pack + <#7> Precision Design USB 2.0 High Speed SecureDigital (SD/SDHC) Card Reader + <#8> Image Recall Digital Image Recovery Software +
- <#9> Precision Design Memory Card Storage Wallet + <#10> Precision Design Deluxe 6-Piece Lens & Digital SLR Camera Cleaning Kit
See more technical details
images Product
Read more Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom Lens + 16GB Memory Card + LP-E8 Battery + Case + Accessory Kit
on Jul 13, 2010 | Cameras
I see to have too much gas pressure after converting my Neptune dryer from natural gas to LP
you should not try to adjust the flame. LP burns more yellow that NG. The gas pressure automatically regulates the airflow based on the dynamic pressure that goes through the burner chamber. If your flame is roaring and pushing forward, everything is Okay, if it is a "Lazy" and falling flame, you have a blockage of the airflow - venting system
Mar 03, 2014 | Maytag Neptune MDG5500AW Gas Dryer
How do i convert from natural gas to LP or Propane?
You need the LP gas conversion kit: http://www.appliancepartspros.com/Appliance-Parts/whirlpool-lp-gas-con-item-number-ap4300853.aspx . Other sources may exist. This includes a replacement orifice and a spring and the installation instructions. The orifices are swapped with a small wrench. The spring fits inside the regulator inside the blocking plug.
You will also need to remove the cap from the regulator and turn it over. This makes the regulator compatible with LP gas. It's easy to tell which side is which - each side is labeled.
However, the conversion kit should be installed by a professional trained for the job. Your local LP dealer should be able to help you find a repair person with the skill. (Improper installation could result in a gas leak.)
I hope this helps.
Dec 09, 2010 | Amana NDG7800AW Gas Dryer
Changing from natural gas to lp.
By getting a gas license! LOL
Remember to tip your waitress! I'll be here all week - Goodnight!
Alright...got it out of my system...here we go:
1. Find out if a conversion kit exists. Answer: Yes it does...in fact it came with it originally. If it had me doing the install, I would have taped the kit to the back of the range.
http://www.fixya.com/support/p106248-kitchenaid_kgsa906pss_gas_kitchen_range/manual-13680/page-7
....and I quote, "IMPORTANT: Your cooktop is factory-set for use with natural gas. If you wish to use L.P. Gas, an L.P. Gas Conversion Kit is included with your new range. Models with the TripleTier Flame Burner will include a TripleTier L.P. Gas Conversion Kit and a kit for standard ranges. See “Installation Instructions” for details on making this conversion.
2. Obtain the kit. This is more difficult than actually doing the conversion. Unless you have a dealer nearby, I'd simply call Kitchenaid directly: (1.800.461.5681) They will either send it to you directly (quite possibly for FREE) or point you in the right direction.
3. The kit will come with instructions, but briefly, here's what you're getting into: The kit will consist of 1-3 orifices. These will reduce the amount of flow going to the burner(s).
Why? Two reasons: a) Propane burns hotter and b) Propane moves quicker than N.G.
You might need: Allan Keys, Screwdrivers, Channel Locks, Adjustable Wrench.
You'll just disassemble the manifold, install the orifice(s), and GO!
Good Luck.
Sep 08, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Convert Maytag Dryer to LP from Natural Gas?
yes it is very much necessary. the natural gas pressure is much lower that LP. it is @3.5 in, water column. The monometer is a pressure reading instrument that will tell what pressure is present at the gas source, appliance gas manifold and gas valve. Read the conversion kit instructions well. And adjust pressure according to data plate specifications. A u-tube water monometer is the best and most accurate however a standard analog will surfice. Please use caution.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MAH5500B Washing machine
Usually, the LR or 'Locked Rotor' indicates a problem with the motor / motor control board or MBC. The MBC is located near the floor on the right side. See www.neptunehelp.com for disassembly photos. The original MCB's had a high failure rate so Maytag redesigned the MCB and the motor. The motor conversion kit is part number 12002039, which includes the new motor, MCB, harness and takes about an hour to install. You can inspect the MCB for either a blown 10 amp fuse or if you see components that are burnt or discolored. If either of these is the case then you will need the motor conversion kit.
In addition, as your Neptune ages you might notice the spin cycle getting louder to where it will sound like a jet plane taking off. If this is the case then you can replace your bearings and seal kit. See www.neptunebearing.com. You can also rent a special Neptune bearing tool called the tony tool which includes the use of a DVD that shows you how to take apart Neptune, replace bearings and install the 12002022 seal kit. I hope this helps...
Jan 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
MayTag Neptune to Propane
buy the lp conversion kit from one off the links here at fixya and it comes with instructions
Jan 01, 2009 | Maytag Neptune MDG9700A Gas Dryer
Maytag dryer conversion
heres the number for the natural to lp canversion kit, complete with instructions. p/n Y33002923, give your local part warehouse a call.
Apr 04, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MAH5500B Front Load Washer Logo
105 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
