Question about Casio EXILIM Card EX-S770 Digital Camera
It won't turn on! I charge it, and the camera is no more than a year old, and yet it wont turn on. However, when it's on it's base, it can connect to my computer and turn on fine! Is it the battery?! Why has it degraded after only one year? And after it's been on the base for a while, the red light of the base starts blinking.
Mine won't turn on...unless I hit the red button, then the menu button, then repeat...the red, then the menu. When the menu comes up, it wants to reset the date/time etc. I just ignore that and hit the menu button once more and it's ready to shoot. Pain in the you know what.
No more Casio cameras.
Posted on Jul 12, 2009
  • 3 Answers
The red flashing after a few seconds means it's not charging - refer to the user guide on the CD. We had this problem - it occurred after the battery was totally discharged. Happened 3 times when battery was left in camera for an extended period and completely discharged, would not charge again. Keep at least a little charge on the battery, or remove from the camera for extended periods.
Posted on Nov 30, 2009
    Problem Solver:
  • 6 Answers
Might be. Happened with my EXILIM camera too. If the power button doesn't work, try using the green arrow button (one used to display pictures) and the red camera button (to take pictures)
Posted on Jun 26, 2009
2 Suggested Answers
SOURCE: charger blinks red and does not charge
This maybe a solution. I had the same issue just now. Pulled battery, put back in, placed on dock, and still blinking red. So I removed the camera from the dock, pulled battery, put same old battery back in, placed on the dock and turned the mode switch on right away before it started blinkin red. It seems to be charging now with one bar and has not gone blinking red for 15 minutes.
I was outside with the camera in 10 degree weather taking pics of my dogs but had been inside for 20 minutes before placing it on the doc. I think something may have happened with the charging circuit and turning it on right away with it on the doc may have reset the charging. Try it. Hope it works for you.
Posted on Dec 07, 2008
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
Battery wont charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 04, 2012 | Canon PowerShot SD1000 Digital Camera
Built in battery wont hold its charge
Aug 21, 2012 | Cameras
Why wont my battery charge at all
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 13, 2012 | Samsung Digimax L60 Digital Camera
Batteries drain very quickly
Apr 06, 2012 | Fuji FinePix S9500 Zoom Digital Camera
My vivitar x345 wont hold charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | Vivitar ViviCam X345 Digital Camera
My camera won't charge, and won't turn on. Should I assume I need a new battery, or is there a problem with my camera?? It's only about 2 years old. Not sure what to spend money on...
If you can't neither charge the battery through USB nor the wall charger, I would advise to first replace the battery. If that does not help, it will be difficult to tell if it's worth repairing or replacing the camera.
Aug 10, 2011 | Olympus SP800UZ Digital Camera
SCL860 Hi8 Samsung Camcorder wont turn on or charge
I don't know if this will help at all but I have had to push the adapter into the camera further than my initial try before it would start charging. Check to see if you can push it in any further.
Nov 30, 2008 | Samsung SCL901 Hi8mm Camcorder
Wont turn on
check out if the battery is fully charged.and even if the battery is very old it does not get charged completely so replace the battery and checkout it should work.
Aug 30, 2008 | Samsung Digimax L830 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
616 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
