Question about Dryers
I have an Inglis Liberator gas dryer that will not sart. I push the button and it just hums. The belt is not broken but it does not turn. Any ideas?? Thanks in advance for any help.
  • bfretz Jun 26, 2009
    No, house lights are fine. No apparent blockages that I can see.
  • 351 Answers
Does the lights dim inside your house? sounds like the motor is hung up... wonder if there is anything in the blower stopping it from moving... let me know
Posted on Jun 26, 2009
  • Mark Nichols Jun 26, 2009
    did you gain access into the blower wheel? does the motor turn freely by hand?
Inglis liberator-start button makes noise but does not start motor?
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Aug 14, 2014 | Dryers
GAS DRYER WONT START
Most likely you have a bad motor or broken belt.
May 15, 2012 | Whirlpool WED5520SQ Gas Dryer
I have an Inglis Liberator Heavy Duty Gas Dryer that has this scraping noice that sounds like the drum rubbing on metal and takes an hour or more to dry cloths! Do you know what the problem could be?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 04, 2010 | Whirlpool Inglis IP8200 Dryer
Push start and motor hums, but nothing else works.
Hi, If you release the start button, does the hum stop? It sounds like hte start winding in the motor is bad. You can try and start it manualy by truning the timer on, open the door so that you can turn the drum with your hand. You will need anoth person there so that one of you can hold the door switch button in and the other push the start button. While pushing the start button, try turning the tub and see if it starts. This will give you an idea on the motor bad or not.
I hope this helps. Please let me know if you need any more assistance.
Thanks
Vic
May 12, 2009 | Dryers
When I push the start button, the unit just buzzes or hums.
You have a broken drum belt. The hum you hear is the motor spinning at high speed.
Apr 21, 2009 | Maytag MDG2706A Gas Dryer
I have an Inglis Liberator Dryer that has always worked great and then last night it sudenly stopped. It was as dead as if I had opened the door. Any ideas what might have happened? Thanks (I don't...
If it is an English Electric liberator dryer, then you are out of luck, as these are now obsolete, and there are no spare parts available.
Nov 17, 2008 | Dryers
Dryers Logo
195 people viewed this question
Top Dryers Experts
