Question about Carrier 38CKC042 Air Conditioner
The unit come on outside but the fan is not spinning. is there a bearing out. we are afraid we will burn the compressor up if we try to run it with out the fan moving
  • 10,865 Answers
Often the power to the outdoor unit is turned off for the winter season. check your electrical panel to be sure that the breaker is on and then go outside and see if there is an electrical control box near your unit which has a power switch or breaker in it.
Posted on Jun 26, 2009
Goodman heatpump fan runs, condenser wont start
Either the condenser fan has bad bearings, or it has a defective fan capacitor.
Turn off the breaker to the outside unit.
Spin the fan blade by hand.
If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
If not, replace the fan motor due to bad bearings.
I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
I'm leaning toward a bad fan motor.
Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
Fan out side is not working
Does the compressor come on? do you hear any humming?
Aug 14, 2011 | Carrier 38CKC042 Air Conditioner
My LG LWHD1200FR air conditioner turns on, but the fan doesn't spin and no cold air comes out. What's the problem? How do I fix this?
Which fan doesnt spin the inside fan or outside fan? If its the outside fan try replacing the dual capacitor for the fan and the compressor. First take the fan blade and see if it spins freely if you spin it and it stops immedietly the fan bearings are bad. If it spins freely replace dual capacitor. If trhis helps please rate me and do a testimonial.
May 31, 2011 | Heating & Cooling
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
THE FAN IN THE OUTSIDE UNIT IS NOT WORKING. INSIDE UNIT RUNS BUT NO COOL AIR IS COMING OUT OF VENTS. IS THERE A REST BUTTON OLN THE OUTSIDE UNIT?
either the fan has went out or the capisitor for the fan is bad and needs to be replaced.if you have run the outside unit very long without the fan turning you might be replacing the compressor as well as the fan or capisitor.if the fan isnt pulling air through the cond coil outside,the compressor gets very hot very fast,and it locks down(burns up). get it looked at asap before it cost more because of other broken parts caused by the fan not working.
Sep 24, 2010 | Bryant Heating & Cooling
Heatpump fan won't run. No noice, except for the compressor.
I'm assuming you can hear the compressor running. The following answer is based on the assumption that the compressor is running but the fan motor is not.
1. Make sure the motor is cooled down by shutting it off for a couple of hours.
2. Restart and immediately upon restart, try to spin the motor blade in it's normal direction.
After performing steps 1 & 2:
- if the motor starts spinning on it's own, it is one of two things: the capacitor or the bearings. If it is the bearings it is often-times difficult to start to spin the motor manually before it takes off. To check the bearings, turn all the power off to the unit....while holding the motor shaft, try to move it in all directions side-by-side (Not up & down). If the motor has any side-by-side movement, the bearings are bad.
- If the motor does not start spinning on it's own, does not feel difficult to turn at any time during the test and the bearings tested "okay", the problem is most likely electrical such as a wiring problem or failed relay. Check to ensure you have the proper voltage going to the motor. At this point, if you have limited experience with electrical motors and controls, it would be best to recruit help from a qualified service technician. Also, you want to look at your warranty on your unit. Many units today have a 5 year parts warranty; however, they have to be installed by a qualified A/C contractor for the parts warranty to be honored.
I hope this information helps you to better troubleshoot and understand your unit so that you can either continue to attempt the repair yourself or have a better idea of where to go for professional assistance. Good Luck! :-)
Mar 07, 2010 | Heating & Cooling
Carrier Compressor Issues?
When you shut it off and back on it slugged the compressor if you turn it off and back on before the pressures equalize between the high and low sides it will slug the compressor and it will not run should let sit for five minutes or so before restarting. The humming is either the compressor making noise usually common for the compressor to make some noise or the fan motor bearings are getting bad on the outside unit. If the unit works normal probably not much you can do till it breaks if it is the compressor it is more economical to replace the whole unit if it is just the fan motor it is worth changing. You could take an amp draw on the fan motor and the compressor to see if the are within the limits on the name plate of the outside unit.
Jan 25, 2010 | Heating & Cooling
Will not run - compressor runs
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 14, 2009 | LG DH30 GoldStar Dehumidifier
I have a rheem air conditioner and the fan spins and it pushes air but the air is not cold enough?
hi! there,
well we have to do something about that,if you mention of fan spin and it pushes air but no cold enough on it,this refer to blower on compressor, there is fan on outside the condenser,so we are on blower w/c does not blow enough cold air,there are factors we can check,first thermostat try to adjust thermostat to the coldest point,
observed if cold was increasing if not, 2nd have clean the filter from evaporator it may have a clogged, check evaporator if there freezing ice on bottom portion of evaporator w/c cold was coming out,have it clean,cleaning this is done by certified a/c technician,there is problem if have an insufficient cold,this is the symptom of your system was under charge lack of freon,this can check by technician w/ clamp ammeter device.the operating current should be equal to rated current on manual,inform service center about this,have a nice day don't forget to rate me.thanks's
Apr 20, 2009 | Ruud UBHC Air Conditioner
Carrier 38CKC042 Air Conditioner Logo
148 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
