Question about RCA 27F650T 27" TV
RCA HD27F754T 1 Solid Red Light, then, 10 Blinking Red Lights
  • guyfrom7news Jun 26, 2009
    I will check that out. Since I bought the TV in early 2007, I must have had this problem 4 or 5 times. I always unplugged, left it for 10 minutes and plugged it back it. It always turned back on. Tonight it happened and nothing, just the lights. It has been very warm the past couple of days, could heat have anything to do with this problem?
    I can see that happening. It is very dusty in my apartment. Thank you for all you advice. Any ballpark price on how much a fix on that type of issue might be?
  • 6,784 Answers
HI. this may be a fly back situation. this is a transformer that is located on the power board section of your set. This device stores and, distributes the necessary AC current needed for proper CRT performance. There is also a horizontal deflection chip that will shut off the transformer if it becomes unstable as well.
I recommend checking the Horizontal deflection chip for damage. if this chip is in good condition, replace the HV Fly back transformer.
Posted on Jun 26, 2009
  • Michael Masters
    Michael Masters Jun 26, 2009
    Well, this unit is a well ventilated set. this is really a dust issue. The dust can settle on the Fly back transform, in return, shorting out the windings. It will create an arch that will destroy this HV device. The damage can cascade to other internal board parts as well.
  • Michael Masters
    The figures will vary from shop to shop but, a good estimate will be about 300 dollars tops.(parts and labor)
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
Sep 21, 2012 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
I need to kno how to program my 8 in 1 jumbo remote to my rca tv
http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
RCA codes: 000,003,004,005, 007,009,011, 015,048,082,092, 094,096,098, 101,102,103,107, 113,125,129, 167,179,187,188, 191,194
1. Press and hold down the CODE SEARCH button •for at least 3 seconds until the red LED lights up solid red.
2. Press the device button , e.g. TV, DVD, VCR, etc. and the LED light will blink once and then remain solid red.
3. Press each of the number buttons 0-9 until the LED blinks once. This will signify the 1st number in the 3-digit code for the device that is programmed in your remote control.
4. Repeat same process to find the 2nd and 3rd digit for the 3-digit code.
5. Once you have found the 3rd digit the LED will turn off.
Aug 14, 2011 | Televison & Video
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Dell dimension 5150 Diagnostic Lights 31 BLINKING 3,4 SOLID
Hi you've either got the wires on the wrong connectors or they need to be turned around, i.e. red needs to be where black is. Hope this helps
Mar 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
All lights blinking
Try:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
May 05, 2008 | Brother HL-2040 Laser Printer
Brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
Got it from here:  http://www.fixya.com/support/t612015-print
RCA 27F650T 27" TV Logo
305 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
