Question about Maytag Washing Machines
Leaking water on top of transmisson - Maytag Washing Machines
  • 6,784 Answers
Replace the tub seal. it is failing.
Posted on Jun 26, 2009
1999 olds alero leaking anti freeze, looks like the leak is coming from between the oil pan and transmission pan. had transmission changed leak seemed to start after that and has gotton worse. Does not...
CHECK HEATER PIPE OR HEATER HOSE AND CHECK COOLANT INLET PIPE FROM THE THERMOSTAT HOUSING. CHECK HEATER OUTLET HOSE FROM THE RADIATOR OUTLET PIPE.SOUND LIKE COOLANT LEAK COMING OFF TOP OF ENGINE.
Aug 13, 2011 | 1999 Oldsmobile Alero
Leak in transmisson line around the trucks radiator
Most likely the rubber hose at the end of the metal trans lines, where they connect to the bottom of radiator
I would disconnect at the trans,cut the rubber hose off,and lay it out on the gound,where you can carefully cut off the furrell and just replace the hose using a clamp on both ends.
May 20, 2010 | 1992 Dodge Dakota
Leaking water from engine block "freeze plugs ???
That means that you have a rusted out freeze plugs so you can buy a freeze plug that can be screwed into place if you can get to the reeze plug, however if it's behind the exhust maniforl you will have to remove the exhaust manifold to get to them. you will need a short hammer and chisal to knock out the old freeze plug. then a wrench to put in a new freeze plug unless you want to put in standard plugs but it is not easy. the freeze plugs rusting are common for this rig. the Freeze plug that has a threaded nut and bolt and made out of high heat rubber is about $5.00 each and can be bought at any Nappa Auto parts or Advance auto Parts store all complete kit for all of them for the stamped steel is about $10.00 however there is one behind the transmisson and hopefully it is not leaking. If it is leaking th transmisson has to come out. Good luck and if you need help just reply to the e-mail you recieve from this site. Thanks for using fix-ya.
Apr 22, 2010 | 1994 Chevrolet S-10 Blazer
2002 chevy 2500hd has water in transfer case
need to drain fluid and refill with clean oil.
Mar 26, 2010 | 2002 Chevrolet Silverado 2500HD
LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
May 20, 2009 | Maytag PAV2300 Top Load Washer
Water leaking out the bottom of my 91 maxima
core plug gone remove gearbox to replace
Nov 23, 2008 | 1991 Nissan Maxima
Maytag washer is leaking
There are special tool designed to dissassemble this unit although it can be broken down without them if care is taken.
Having the model and serial number would help but be assured that the threading is standard (Rightie tighty, lefty loosy)
Maytag used different designs. Repair depends on the model/serial number. With this information I may be able to step you through the repair.
Knowing the age of your machine would be a plus in determining if repair is economically feasible.
Jan 02, 2008 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
