Question about Speed Queen AWS52NW Top Load Washer
Washer was running normally. stopped during 1st stage of delicate cycle. 4 items in tub, small load chosen for load size, warm wash, cold rinse. washer stopped, slight smell of 'burnt' motor. will not start again. no functions working. waited 3 minutes for motor overload to reset. no change. how do i determine if it the motor/transmission or other thanks
  • 1 more comment
  • roccman Jun 26, 2009
    how would i go about checking the motor?
    what is the specific location of the capacitor?
    i have an amana washer(alw880qaw). it was running normally. 1st stage of delicate cycle/warm wash-cold rinse/small load size. 4 items in tub.
    stopped, will not restart. if the capacitor has failed, how will it appear visually?
    please give me specific instructions on how to check the motor if my visual inspection of the capacitor suggests the capacitor is ok.
    thanks
  • 952 Answers
The best way to check if a capacitor is OK is to get an electronic tester. Motors don't usually go bad. It is the toughest component in machines. Im 90% sure that its the circuit board that is problematic. Just get yourself a tester and test the capacitors. if you don't know how to test. ask for an electrician to test the circuit for you. Have a nice day..
Posted on Jun 26, 2009
    President:
  • 2,923 Answers
There are two possible cause.
1. The washer's capacitor
2. The motor itselt
You need to check the capacitor if it's pregnant or not. You can easily determine if the capacitor is defective by looking on its physical appearance. The capacitor usually looks like a cylinder tube (for washers only) and it has a markings. The usual markin is 10UF. The capacitor will not cost too much, probably around $5 or more.
But if the capacitor is okay, then you might need to check or replace the motor.
I would suggest you to contact a repair person to check it or to contact the manufacturer if the washer is still under the warranty.
Have a great day!
  • Melvin Ramos
    Melvin Ramos Jun 26, 2009
    You might need an assistance of an experienced repair person, usually, they remove the motor out of the washer and they check first the appearance and they have a device that they use to check if the motor is okay or not.
  • Melvin Ramos
    The capacitor's location is at the back of the washer near the motor. It is connected by a red and while wires. Look for the marking 10UF or higher. Once you see a "UF" mark, that is the capacitor.
Wash cycle runs for a few seconds, then stops for 15 seconds--over and over.
Depending on the cycle chosen, this may be perfectly normal for a front loader. I recommend reading the owner's manual to see if that is the case. I own an LG front loading washer, and it does the same thing when in a delicate or permanent press cycle. Try putting it on a heavy cycle. If you don't have an owner's manual for it, you can go to Bosch online and download the manual from the manufacturer.
Aug 02, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore 44832 hot water won't stop.
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve Adefect in the water-inlet valve may mean that it's no longer able toshut off completely when the electricity has been turned off to it. Ifthis occurs, the valve may leak and drip water into the clothes tub. Intime, the water may accumulate substantially. If this happens, you needto replace the valve.
Water-level switch Adefect--or an obstruction--in the water-level switch may mean that itcan't tell the water to shut off. So the machine overflows. This switchsenses the water level in the clothes tub. It's usually a diaphragmdevice with a small, clear tube attached between the switch and thebottom of the washer's outer tub. As the water level in the tubincreases, the pressure on the air in the tube increases. When thepressure reaches a certain level, it activates the switch, shuts offthe water, and signals the timer to begin the agitate cycle. You caneither clear any obstruction in the tube or replace the water-levelswitch.
Aug 03, 2008 | Kenmore 44832 Front Load Washer
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Clothes too damp after spin cycle
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Washing Machines
Clothes in bosche washer gets tied up in knots in spin cycle
Are you running a load according to the care labels?? If you run delicate or easy care items on a cotton wash this can happen. Just because an item is 100% Cotton doesn't necessarily mean it will tolerate a cotton cycle check the care label. Also, if for example a cotton cycle is 6Kg, the easy care will be 3-4Kg, Delicate and woollens will be approx 2Kg. Overloading can cause items to knot during cycle. Finally, check that your inlet water is not too hot. Repost if you need any further assistance
Feb 19, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Whirlpool wtw5tesvno
Hello.
Whirlpool washers are available in many colors and with different options, including various tub sizes, front or top load styles, a fabric care system, high efficiency wash features and energy, time and water sensors. The washers may be purchased in department stores, home repair stores and online. Many are Energy Star rated. However, the washing machine may malfunction occasionally and not agitate or spin. If this occurs, some troubleshooting steps may be useful in solving the problem.
1 sure the washer has electrical power and is connected to a grounded electrical supply. Replace or reset the circuit breaker or fuse if needed, particularly in event of a recent power outage. Make sure the washer lid is closed tightly before use; the washer won't work if the lid is open.
2 void selecting the following cycles: "Extra Low,, "Low," "No Spin", "Delicate," "Casual/Perm Press" or "Hand Washables." All of these cycles use little to no spinning or agitating during the cycle. Select the highest possible spin cycle for the fabrics being washed.
3 pen the washer lid and redistribute the load; unbalanced loads may cause the washer to stop or slow down. Add additional items if only one large item,
such as a rug or blanket, is in the washer.
4 Use only the recommended amount of laundry detergent, as excess sussing can reduce the overall spin speed or cause the washer to stop agitating. If the Whirlpool washer is a high-efficiency model, use only high-efficiency laundry detergent.
5 Examine the drain hose and straighten if kinked. Remove any possible obstructions and ensure the end of the hose is no more than 96 inches from the floor, as this will cause water to flow back into the washing machine.
Thanks.
Nov 13, 2011 | Whirlpool Washing Machines
Magkakatuluyan ba kami ni shelumiel
Instructions
things you'll need:
* Laundry detergent
* Clean cloths
* Measuring tape
* Plywood (if necessary)
* Wrench (if necessary)
1.Verify that the Kenmore top-loading washing machine is completely plugged into a grounded, three-prong power outlet. Reset the fuse or circuit breaker, if necessary; do not plug the washing machine into an extension cord.
2.Make adjustments to the feet on the washing machine if it is shaking or vibrating. The front and rear feet must all be touching the floor evenly. If the floor under the machine is flimsy and cannot adequately support the washer, set a 3/4-inch piece of plywood under the machine for better stability. Load the tub evenly when placing items inside the washing machine and do not overload the tub.
3.Examine the washing machine drum, including between the inner and outer basket, if the machine is clicking or rattling during use. Remove loose objects from inside the drum. If objects are caught between the drums, unplug the washing machine and pull the items out with a pair of pliers, if possible.]
4.the fill hoses behind the washing machine if there are water leaks and ensure the drain hose is connected to a laundry tub or drainpipe. Look at the plumbing throughout the home for drainage problems and correct as necessary.
5.Turn on the water valves behind the washing machine and clean the water inlet hose screens if the water is not running or filling. Do not overload the tub, and use only high-efficiency (marked HE) laundry detergent in high-efficiency Kenmore washers. Note that energy-efficient washing machines often use less water than other machines; this is normal.
6.Choose a wash cycle with a higher spin speed if the water is not draining as expected or items are extremely wet when washing is complete. Reduce overall load size and select a new drain/spin cycle to remove the extra water from the washer. Ensure the drain hose is properly installed on a drainpipe or tub and is not set more than 96 inches above the floor.
7.Reduce the number or volume of items inside the washer tub if the clothes are not rinsed when the cycle is complete. Verify that the water valves are turned on and the correct type and amount of laundry detergent is used.
Mar 12, 2011 | Kenmore 22422 Top Load Washer
Grease looking stains on clothing after washing in front load washer. Not on all clothing just certain items. Normally notice it on darker colored clothing.
that is leftover soad and down that is building up inbetween the inner and outer tub .....
frontload washer tend to wash in cold an d luke warm water down and most softner detergents are mader from animal fat means it not getting washed away so it cakes up and eventualy this cake deosit get heavy enouhk and fall and fet redeposited on yoour clothes ..... make sure you are using high efficiency soap and run a clean cycle every month with the hotest water cycle with a afrresh tablet for front load washers
Jan 24, 2011 | GE WSXH208A Front Load Washer
Machine stops during the wash cycle.
Hi this is abhishek,welcome to fixya
over weight normally doesnt cause machine to stop during the wash cycle,,iit is actually tub gettiing stuck or a timer problem...
thank uy........
May 03, 2009 | Bosch Logixx WFR 2867 Front Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Speed Queen AWS52NW Top Load Washer Logo
90 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Charles T Nevin
Charles T Nevin
fta777
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
