Question about Soleus MAC-10K Air Conditioner
Unit starts cooling for about 3 minutes and compressor kicks off and hot air stats blowing out soleusair mac 10
Your unit is out of frion or cooliant im SURE!!!
Posted on Jun 05, 2010
We have a Goodman CKL 3.5 ton 10 seer AC unit. it is labeled Amana Distinction. it is installed in 2006. CKL 42-1L. The problem is that when the wall thermo control kicks on, the fan blows 3 minute of...
Yes there is a way. First You need to see if the outdoor unit has a time delay on it.It would be connected to the contactor and the low voltage wires. If there is not one then there is a problem with your thermostat. If you have the thermostat manual, check to see if there is way to change from the 3 minutes to none. I hope this helps you.
Jun 05, 2011 | Goodman CKL24AR24 Air Conditioner
A C blowin hot air. cecked unit outside. Fan is not blowing. Turned off, allowed to cool off. Unit worked 10 minutes. now blowing hot air again
Sounds like another problem with the capacitor being bad, if you cannot hear the compressor operating either this may be the case.
Jun 25, 2010 | Heating & Cooling
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Jul 31, 2008 | Kenmore 75101 Wall/Window Air Conditioner
Cooling problem
Since it is not so hot outside you may have to adjust the Thermostat to a lower setting to get the AC unit to kick on the compressor and blow out cold air. Give it a try, and if not the T-stat then we can go from there.
Jul 14, 2008 | Office Equipment & Supplies
Not cooling
every single component in your cooling unit is needed for it to work, so anything can shut it down. If you could provide more information as to what type of unit you have: is it a central heat and air package unit? or central split system (furnace indoors and condenser outside)? or a wall a/c? Does any part of the system/unit do anything?
Apr 27, 2008 | Heating & Cooling
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Soleus MAC-10K Air Conditioner Logo
302 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
