Question about Sony KV-27FS13 27" TV
Problem with sony tv
I have a problem where the right hand side of the picture bends in, the gap at its widest is approx 3inches, after a while the set switches itself onto standby mode. If you switch it off and back on again it will work for a short
while before doing the same again. As the set warms up so the shorter time the set stays on.
Please if you can tell me if this is a serious problem or something simple
  • 934 Answers
Define serious and simple.. Just teasing... John what you have is called a pincushion problem. In that particular model I'd check the following:
C530 .0022uf
R530 15k
R532 4.7k
and Q503
If you're not too technically inclined try this. Remove the main board, called the "A" board. Take pictures if you have too to refer to later when you re-install the board. So you know where all the wires go. Then carefully box it up and send it in to tri state module.. For approximately $129.00 plus your shipping costs getting it to them they will rebuild the board and ship it back with a one-year warranty. Re-install the baord and problem solved.
On the other hand, knowing that Tri State will rebuild it for that cost call a few shops and ask what they charge for repairing the pincushion problem, can't hurt.
Tri State's web is: http://www.tristatemodule.com/
Posted on Nov 05, 2007
Sony kdl52xbr4 tv has double vision on right side of screen perfect picture on left side is this a timing control board issue?
Fault with its T'Con board itself. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 14, 2015 | Sony Televison & Video
Anyone have a picture of connections for a indesit idv65 tumble dryer,changed my belt and they fell off before i could take a picture of them
undo all of front (leave wires attached),,,, undo sides (take screws out of left and right sides approx 10 screws at back),,,,place belt round drum near mark left by old one,,,, lean on front of drum to lower drum to the motor spindle,,,,,,pushing hard down on drum will bend the drum on the inside as it touches the motor housing (don't worry it bends back),,,,,,,you should then have the drum close enough to the spindle to lever the belt over by hand,,,,,pull drum back up,,,,,rotate by hand to let the belt self align,,,,shouldn't come off spindle if you put it on with 3-4 grooves spare,,,,,, do back up (10 screws),,,,put front back on and pull drum onto the lip on the front of the frame, the new belt may be squeaky until it is wore in, Hope this helped Tim
May 28, 2011 | Bosch Dryers
Screen dark on right hand side at start up
Suggest return or exchange. This is a newest model, and on factory warranty, if can't return or exchange, you have to complaint it until the panel is replaced. in fact, it is 90% panel defective. right now the LCD panel quality is too bad.
Jun 17, 2010 | Sony KDL46EX500 46 in. HD-Ready TV
The color is fading in our KV-32FV26 Sony Wega The TV is approx 3 years old.
my sont tv model no. KV-XF21M83 (21 in's) indicator lamp flashes red a number of times between 3 secounds interval
the color of the tv has gone faded. The channels name on the top right or left side is not seen properly
The EHT is sparking near the picture tube.
Nessarry guidence may please be comnicated in this regard please. send me feed back to my email adress
sikandher@hotmail.com
Mar 13, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron - Picture Disappears
Hi, IK circuit is engaging which basically means the picture tube is getting tired, the only "fix" is temporary (may get another year out of it). You have to increase the "screen control clockwise".
Remove back of set, follow large black or red wire attatched to picture tube down to the flyback transformer, mounted on flyback are two black controls, one is focus (leave it alone) the other is "screen", adjust it clockwise approx. 1/4 inch, remember that this is a high voltage circuit so use one hand in the set the other hand out of the set at all times,any questions ? e-mail me back, good luck, BMW Rider
Feb 27, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Vertical Lines of Sony Bravia 46
IT CAN BE FIXED BUT NOT BY YOU
BOARDS NEEDS TO BE REPLACED OR RIIBON CABLES NEED TO BE RESEATED. YOU CAN DEAL WITH A SERVICE COMPANY(NOT ALL ARE AS GOOD AND KNOWLEGABLE AS THE ONES YOUR READING HERE)
OR EXCHANGE IT
YOUR CALL
Feb 21, 2008 | Sony BRAVIA KDL-46V3000 Television
Sony KV-32LS60U FD Trinitron 32
Your tv has Leak cap in POWER supply its either primary or secondary power. Need to replace it. Look for a Electronic Tech.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Picture problems
Convergence IC's need replacement,moderate technical ability
needed......cost about 400.00 to repair..................T.
Nov 17, 2007 | Philips Magnavox 51MP392H Rear Projection...
Problems with my sony kv32fx20u tv
sony kv36xbr400 wega I have a 5inch black line across top and bottom & gray side to side making a smaller picture.
Nov 16, 2007 | Televison & Video
Sone TV Picture not aligned.
This looks like Pincushion problem. nothing you can do. Only a Trained technecian can do this adjustment to reproduce a perfectly aligned image. It requires a pattern Generator and other tools. call the company tech.
May 10, 2007 | Sony KV-36FS100 36" TV
Sony KV-27FS13 27" TV Logo
52 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
