Bryant 463AAC008BA Air Conditioner
Problem for Bryant 463AAC008BA Air Conditioner
Compressor Noise transfering into home
By servovalve on Jun 26, 2009
I have a new Bryant A/C unit in a new home. You can hear a awfull vibration in the lines comming from the wall inside the house. The installers came out and could not figure out the noise and it's not loose lines in the wall.. They took readings and everything is OK.They got with Bryant, came back a week latter and zip tyed some hard rubber onto the outside lines and left. Now it's worse than before and I can't get ahold of them. I think the compressor is bad.... Made in China or something... but I am no expert. I need help in order to tell them what's wrong because I am getting the run around !!!!!
Thanks !!!!
Comments:
Jun 26, 2009
- Thank you for your experenced insite! I watched the home being built from the ground up and I checked the lines before the Brick and Drywall went up. I had heard of these problems before so I was on the lookout. There are no vibration pads under the unit and it sits on a cement pad. There are 2 units and only one does this. I will contact the builder and see if he can get ahold of the installer at which time I will relay the great advise you gave me to them. There is a lot to be said of 45 years experence !!!! Thank you ! Jim
Best Solution
posted on Jun 26, 2009
Very Helpful)
james3751
Rank: Guru  Air Conditioners  Expert
Rating: 91%, 211 votes
This can happen if the unit was not evacuated and there are non-condensables in the system. Sometimes a line rubs against a floor joist. The compresor can put out a high freqency hum thru the lines. Change compressor. Make sure they evacuate the system. The pressures can be OK when you take them but when the unit reaches a certain pressure it start the viabration. Does the unit have viabration pads nder unit. It can be fixed. I just listed some things I have run into over the last 45 years of service. Rus
Comments:
Jul 05, 2009
- Did you solve your problem. Please reply
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Bryant 463AAC008BA Air
Questions and Unsolved Problems for Bryant 463AAC008BA Air
Do you recommend Bryant 463AAC008BA Air Conditioner?
Answer
Answer
I have a Carrier MOD# FA4A and the inside unit is runing accordantly with Termostat but the uni... (More)
Answer
Armstrong Heat pump Package Unit, Model#PHP10B36DA-9B, Serial #165D03488. Unit freezes up when... (More)
Answer
Having problems with Carrier 58RAV furnace. Goes through the motions, but gas never turns on. I... (More)
Answer
reparar placa aire acond, WW-2250 FC
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , AK
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
