Question about Hayward SAND FILTER, PRO SERIES
Problem with vari-flo multipoer 1.5 and Hayward DE fiilter
My pump/filter does not get sufficient water when the var-flo is on "filter" However, when I change the setting to "recirc" or "waste" the water flow is fiine. Also, I see water going out of "waste" line even when the setting iis for "filter". What is the problem/solution. Thanks for the help.
    President:
  • Hayward Master
  • 1,378 Answers
You need a rebuild kit for the valve and possible a sand change. Sand should be changed ever 3 - 5 years or so depending on overall pool conditions.
The gasket inside the valve is out of place and therefore allowing water to leak out the waste port. Use a gokit to replace all the gasket/orings and you should stop the leak.
If the flow is still bad, inspect the sand and change it if necessary.
Posted on Jun 26, 2009
Hayward vari flo valve on filter also comeing out waste at same time
Yes, it is the "spider" gasket inside the valve that has gone bad. It needs to be changed out. They are not expensive. Go to YouTube and enter "change spider gasket" there are several videos. Good luck with it!
May 11, 2013 | Pool & Spa
I have a 20,000 gal in ground pool w/ Hayward 36 sq ft de upright filter, Hayward Vari-Flo valve. Actual suction at the skimmer has gotten very weak, (filters and traps clean) It does better in...
You say that you can see a large flow through the pump cover but that water must be coming from the pool somehow. It must be coming through the main drain. If you turn the main drain off then the flow from the skimmer should increase considerably. If it doesn't the issue could be caused by a nearly plugged line between the skimmer basket and the pump. I have had similar symptoms and I started by using a drain jet device on a hose to force water backwards from the pump to the skimmer with the main drain valve turned off. I couldn't clear the plug so I had to dig the line up and found a bad area of the piping where it made a reduced pipe size 90 degree turn. Sycamore bark, leaves and twigs were stuck at that pinch point.
I hope this helps.
Sep 05, 2011 | Hayward 36 Sq Ft Pro Grid Vertical Grid De...
Hayward vari-flo sp0710xr50 install manual for piping
I don't have a manual but basically the intake of the filter connects to the area around the grids. The inside of all the grids connect through a manifold and pipes to the output port of the filter. The pump output should be piped to the return piping of the pool. If you have a heater it should be connected between the output of the filter to the return piping of the pool. If you have a chlorinator the output of the heater it should be connected through a metal-free check valve, into the chlorinator and then to the return piping of the pool. I hope this helps.
Aug 13, 2011 | Hayward EC-40 DE Pool Filter with pump
Water and de backflo into motor from filter
Try checking the users manual. I don't have an exact answer for you, unfortunately, but the users manual for these pool filters is comprehensive and has diagrams. Hopefully, you can find your answer there.
http://www.backyardcitypools.com/images/hayward/perflex-system-manual.pdf
Jun 02, 2010 | Hayward EC-40 DE Pool Filter with pump
My DE pool filter stops working after an hour? please help
Is your pool green? This will cause the filter to plug up. When you say stops working do you mean no water flo, passing dirt or are we talking about the pump not moving water? Can you clarify this problem some?spellcheck.gif
Aug 16, 2009 | Hayward EC-40 DE Pool Filter with pump
My pump will not push water back into pool,what could be the problem?
check pump basket make sure its clean if you have de filter it is dirty back wash and add new de make sure all valves are open
Jul 11, 2009 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Hayward vari flo filtering system
Check to make sure the plumbing is in the correct inlet/outlet on the valve head. Sounds like it's plumbed backwards. Inlet is from the pump, out to pool...
May 10, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
727 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
