Question about Tomtom GO 720 GPS Receiver
Tom Tom Go 500 not recognised by computer
I have reset and downloaded my drive connect to the computer. But to no avail as my computer will not recognised the new hardware that is connected via a usb cable. Anyone with an answer. As this is driving me insane
    Sergeant:
    Champion:
  • Tomtom Expert
  • 373 Answers
You cannot see your new 500 on the PC,
my drive connect is a net server and this is how you purchase updates from now on.
Posted on Jul 17, 2014
SOURCE:
RAC_ICS
  • 143 Answers
SOURCE: PC does not recognise TomTom
Dont use a HUB, connect it directly to the PC.
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Posted on Dec 16, 2007
homemender
  • 158 Answers
SOURCE: computer won't connect with download.tomtom.com
download.tomtom.com is not a web-address. Try this link to the 'home' download page > http://www.tomtom.com/plus/service.php?ID=17
Posted on Jan 27, 2008
E61N
  • 515 Answers
SOURCE: tom tom go720 device isn't recognized by tom tome home
http://www.tomtom.com/support/index.php?Language=1&query=connect+to+home&FID=7375
Posted on Jan 14, 2009
E61N
  • 515 Answers
SOURCE: Tom Tom 500 says memory card not installed
Red cross issue:
http://www.tomtom.com/support/index.php?Language=1&query=red+cross&FID=1898
Device not recognised by PC:
Device not recognised by TomTom Home:
Posted on Apr 13, 2009
  • 5 Answers
SOURCE: Tom Tom Go 520 Wont connect via USB
It sounds like your mini usb connector is damaged. If you're handy you can buy a replacement and solder it in. You will need a very fine tip soldering iron and a magnifying glass. The repair can be quite challenging as the components are surface mounted.
Otherwise I can fix it for you for a small fee.
I've repaired about 20 tomtom units with similar problems. I charge around £35 for this including return postage
Posted on Oct 08, 2009
Hello, We recently purchased a Tom Tom 140s, used it two times and it went out on the second time we used it. We cannot get it to start again. Any suggestions?
Try a soft reset first - hold the on button down for 20-25 seconds to do this. Most of the time this will fix starting issues.
If the tomtom still won't start you need to connect to your computer via usb cable and start tomtom home (downloadable from the tomtom website) - an auto update should fix it if the tomtom is recognised.
If tomtom home cannot recognise it (shows no device connected) contact tomtom customer support who will send you a software reset - then eventually you wil be back up and running!
Nov 15, 2010 | Tomtom ONE 140 GPS Receiver
Wont connect from lg pc suite
Happened to me a few times. Try restarting your computer but leaving it plugged in so your computer already recognises what it is.
If you plug it in your computer takes 10 minutes or so figuring out what it is and whether you need to download anything additional for it to work. If you restart your computer by the time you click LG PC Suite it will have already recognised what it is and will work. If your computer has wireless settings you could try connection through bluetooth!
Mar 20, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Tom tom home does not see my tom tom go 520
Hi canal_boat_m
Try this solution:
STEP 1 Un-install Tom Tom Home from your PC
STEP 2 Click on the link below:
http://tomtom.com/lib/img/cs/S4S/files/RemoveRegEntries_TTGOv1.exe
This will download a little removal program for the Tom Tom Home program.
A Black window will appear briefly then close.
• Make sure that you have got Administrator rights on the PC. Otherwise you may not be allowed to connect new hardware (especially the case when using office computers)
• Reboot your PC
STEP 3 Visit Tom Tom website and download the current new version of Tom Tom Home and install it to your PC
STEP 4 Connect the TomTom
• Make sure the device is fully charged before connecting it to the computer. Ideally a mininum of 4 hours charge.
• Reset the device using a paper clip (see http://www.tomtom.com/6965). When resetting, keep the reset button pushed in for at least 20 seconds, but DO NOT turn the device back on just yet.
• Ensure that your TomTom has power connected to it. There should be a green light on the TomTom unit. If your device came with a Home Charger, please make sure that is plugged in to the TomTom also.
Your Tom Tom should ask you to 'Connect to Computer' if it does tap YES.
SOLUTION:
Your unit should now be recognized by your PC.
IF IT DOESN'T then follow the instructions below:
1. Connect your unit to your PC;
2. Copy two folders to your PC (namely 'Raster' and the one which holds all your maps - probably called 'United Kingdom and Eire';
3. Using Windows Utility, right click on the Tom Tom drive unit and select Fomat;
4. Switch off the unit and soft-reset it with a paper clip (but hold it in for at least 20 mins) and then re-connect it and power it up;
5. Tom Tom Home should now detect the unit and your unit should ask you to 'Connect to Computer' so tap YES;
6. Tom Tom Home will now say your device needs updating - and if you apply all the changes it will restore it to Factory Finished!
7. Then all's needed is to replace the two folders you backed up and any other items like mp3's and sounds, pics, etc.
Feb 27, 2009 | Tomtom GO 520 GPS Receiver
What I can suggest is download the drivers & software first .. Than buy another brand of memory card.. I had same issue with a Mp3 player that I had purchased.. It wouldnt recognise the card even though it was setup properly.. I returned it and baught a different brand.. Worked Like a Charm..
#2 If you for some reason cant get the software to install or work properly, I suggest you buy a new Tom Tom (( EXACT MODEL )) and than take the old Tom Tom put it in the new box and take it back with your receipt and tell them this doesnt work.. Ive done that b4 with a Speaker system and it wasnt an issue with the store...
Good Luck !
Feb 24, 2009 | Tomtom GO 700 GPS Receiver
The computer does not recognise the Tom Tom
Try to reset the TT device, use a paperclip at the bottom of the unit. Start unit again, and try to reconnect.
Apr 10, 2008 | Tomtom One Europe v2 GPS Receiver
Tom tom 300
"My tom tom wonts switch on. I have reset it and still it comes on with a boom boom noise and shows the 2 hands on the screen. It also shows the loading bar at the bottom, but then it just freezes and nothing happens. can anyone help please ASAP"
Sound as though your Map data card is corrupt. Remove the SD card and check it with your computer using a card reader. Backup the SD card onto your computer. You can run either chkdsk or go to the drive letter under 'My Computer' right click and select properties, then tools, then check now. You can also try starting the Tomtom with the SD card out of the unit. It should show a picture of the Tomtom with a 'X'. You can also try copying the data on the SD card to another SD card.
Sep 12, 2007 | Tomtom GO 300 GPS Receiver
Tom tom go 500 wont power up
Press the power button for 15 seconds and your tomtom will turn on with the drum sounds yor tomtom will now reset but nothing will be deleted off it and it will now hope fully work.
Bye
Apr 27, 2007 | Tomtom GO 300 GPS Receiver
Tomtom GO 720 GPS Receiver Logo
70 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
