Question about Archos 605 WiFi Digital Media Player
I got water on the screen and it isnt turning on what is wrong and how can i fix it
Please dont even try to turn on the device. water went inside and there may eb some problems with the circuit now. Get it immediately checked at the service center or with any technician.
Posted on Jun 26, 2009
How can my iphone4 be fixed after bad water damage ?
At this point you have nothing to lose by trying the alcohol trick. Put it in a shallow dish, cover it with rubbing alcohol. Once its fully covered, remove it and let it sit for 15 minutes. Get rid of the alcohol. Then try turn it on. If there is any residual water trapped inside when the alcohol evaporates it will take the water out with it. Be careful, alcohol is very flammable so make sure there are no open flames or possible sparks around when you do this, its better to do it outside. You can try it, but do it at your peril!
Nov 09, 2014 | Apple iPhone4 4G iPhone 4
Whats wrong with it?
sounds like something isnt clipped in properly or it isnt sensing that the water is in the reservoir
May 25, 2014 | NewAir AI-200SS Stainless Steel Portable...
Motor runs fine, no pressure
do you h ave water supply make sure inlet screen isnt clogged. 0utlet hose or nozzle isnt clogged ,turn up pressure control valve could be bypass valve problem or internal valves are stuck or ddestroyed also pistons did it ever freeze with water in it during cold weather?
Jul 05, 2011 | Garden
My samsung s5233 is not working. the screen not responding. how can i fix it.
if your phone isnt responding at all??
i mean if u are able to do some basic task then there must be some software issues which can be solved by UPGRADING FIRMWARE.
but if the touch screen isnt reacting at all, then there must be the hardware problem and for that you should visit customer care or repair shop.
please note that upgrading FW at your own is risky as, if anything goes wrong, then your phone will be BRICKED.
Feb 28, 2011 | Samsung Star GT-S5233 Cell Phone
Washing machine flashes error code e10 & is not filling with water
Check to make sure water supply is fully turned on. if the water supply is fully turned on, then check to make sure that your hoses are straight. if that doesnt work, tun off water supply, disconnect hose connection to the water inlet valve and check to see if the screen is dirty. you can use a small brush to clean it. if the screen isnt dirty then you may need to replace your water inlet valve. if the screen is dirty and you want to remove the valve let me know and i"ll walk you through the steps.
Feb 02, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Stopping mid cycle, not taking softner, doing a
OKAY.....Could be cold water not entering the machine , due to turned off. or faulty valve coil not too expensive to fix...
May 24, 2010 | Washing Machines
I spilt water on it and now the screen doesnt work
if the screen is turning on then you should be fine just take it to the apple store and ask for them to fix it if the screen is working it shouldent cost you as much for when the screen isnt turning on at all
Jun 06, 2009 | Apple iPhone Smartphone
ED5PHEXRQ00
There could be a number of problems. Some ways to try to find the problem would be to check and see if there is ice in the icemaker which would mean there is probably something wrong with the mechanism that empties the trays. Or if there isnt any ice, there there is something wrong with the water dispensing system. If you can figure either of those things out it would help in figuring out how to fix it.
Oct 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Wont fill with water
I probably has a bad fill valve or a clogged screen suggest check to see if the fill valve is engaging and if there is water getter past the valve.
Jan 20, 2008 | Whirlpool LTE6234D Top Load Stacked...
Archos 605 WiFi Digital Media Player Logo
49 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
