Question about Advueu Technology AMW-F196B
My F199B seems to have a bad display after
My F199B seems to have a bad display after installing fresh windows 7. The display is all messed up and cant see anything but jagged lines. I have a 9800gx2
  • edik Jun 26, 2009
    I did that , still doesnt work. I used nvidia 186.xx driver for windows 7 64bit .
    President:
  • 1,179 Answers
You need to download & install the Windows 7 druvers for your graphics card. Once this is done your display should be fine. Hope this helps.
Posted on Jun 26, 2009
  • Roy Lonsinger
    Roy Lonsinger Jun 29, 2009
    Check to see if your monitor requires any drivers for windows 7 as well. Some do & some do not.
My aspire one has windows 7 and it's missing drivers. When I try to find them online it can't find them
Missing drivers seem to happen with windows 7. You can try booting up your computer with the original Windows 7 DVD - but DO NOT do a fresh install - do a windows repair. Hopefully the missing driver will be installed and you will not loose any data.
Good luck - it that fails it might be a good time to upgrade to Win 10 - I have found that it is quite stable and takes care of all Win 7 driver issues.
May 04, 2016 | Aspire Computers & Internet
Reinstall windows 7
Most laptops have what is known as a recovery partition on the hard drive. This partition has a mirrored image of the factory-installed original configuration. Check your users manual to see to how access this partition. If you can boot Windows, some manufacturers have set up the ability to do the recovery from the OS. If the OS is so badly messed up that your can't boot to it, there is usually a hotkey combination that you press at bootup to get to the recovery routine. You may also have received or made a set of recovery discs when you purchased the laptop. These can also be used to return the unit to factory fresh condition. If you have neither, you will need to use a Windows 7 Installation Disc. This will install the OS, but will in most cases, not have all the drivers you will need to activate all the installed peripherals such as network NIC, sound, bluetooth, etc. These drivers can be found and downloaded from the manufacturer website. You need to know the Model number of the unit and the OS you are trying to download drivers for.
Mar 05, 2015 | Computers & Internet
Error code OX45d and the ASUS boot disk can not finish fresh install.
Your hard drive has some bad sectors and Windows 7/8 does not want to be installed in the problematic hard drive. They are require a healthy hard drive.
Feb 14, 2014 | ASUS Computers & Internet
Internet explorer keeps popping up window internet exploere has stopped working
13-1020US Notebook a Notebook (who OS< what windows is it ?)
real name
HP Folio 13-1020us Notebook seems like your unstated OS is infected to me.
it came with windows 7 or 8 new.! a fact.
is it still 7 or 8? or did you do the 2016 free W10 update (bad) from Microsoft./??? we can not guess OS here, ever.
click control panel, click system behold , OS true name. tell helper this...
sounds kinda like....
Windows 7 H3LL, this OS has over 350 updates!
and IE11 is now mandatory or the UPDATES stall or scramble up
1/2 installed and all messed up.
w8 is far far better OS, id up grade now if not there now. at HP.
seen fresh loads (many) of W7 , after the fresh load installed
IE11 fails to update to v11.
but it must, so goes mad like that. its problem at MS
they have the worst W7 update engine of all.
many folks had to abandon IE due to the above, and run Chrome.
or better Firefox, I dont run IE ever, since day 1. so.....
how to fix this, can be hard. (i have a cure but cant teach that I have a slip-streamed W7 disk that loads and just works with all updates)
Microsoft has special tools to make this happen and new ISO made. (ask)
My only answer is this.: (in all cases back up your data first)
Google for #1
1: run many online virus scanners, disinfect the system.
2: or reload w7, via the HP F11 key. power on hit f11, over and over fast until the RESTORE screens pop. then reload V7.
restore the OS, and then pray MICROSOFT update work right
Im told they cured some bad software they had,so might work.
NOW..
I updated mine to w10. for a more secure system....
My PC can not be upgraded to 10, for hardware reasons.(ask)
btw the real HP forum is here , we are not HP,
https://h30434.www3.hp.com/
Jul 08, 2017 | HP Hewlett Packard Folio 13.3 13-1020US...
Vmfusion emulation of windows 7 language change
How to change the Windows 7 Display Language:
1. Go to Start -> Control Panel -> Clock, Language, and Region / Change the display language
2. Switch the display language in the Choose a display language dropdown menu.
3. Click OK
4. Log off for the changes to take effect (This will affect only the user profile under which you are currently logged on).
May 05, 2012 | Apple iMac Computers & Internet
How can i get windows 7 on this particular device? I keep getting a message saying that it's not compatible. I'm sure it can be done, am I missing something? Trying to install 32bit windows 7 ultimate...
you are unable to upgrade for Windows XP to 7, you have to do a fresh install which involves a format which will mean you will lose all of your data unless you back it up
if you are running Vista you cannot upgrade from Vista 64bit to 7 32bit, again you have to do a fresh install
to do a fresh install insert the Windows disc and reboot your computer, make sure your computer has it's boot priority set to
1. DVD Drive
2. HDD
and if that's done correctly just follow the prompts to install windows.
Mar 20, 2011 | Computers & Internet
I have an acer 4315 laptop running on windows 7. when i start up the laptop the screen displays normally. However, jst when the welcome screen comes, the screen becomes blured. The screen displays normally...
it seem the display drivers gone bad, mostly these kind of problems fixed after driver installation otherwise you may need to install windows again after formating
Nov 01, 2010 | Acer Aspire 4315 Notebook
My pc seems to have vireses. it has window xp and can it also be updated with windos 7
Microsoft does not recomend yo to upgrade fron windows XP to Windows 7. Fresh installation of Windows 7 on an XP machine is recommended.
Backup your User file, do a windows 7 readiness, and insert the windows 7 DVD into you systems fro a fresh installation.
However, there are third party application like PCMover software that could help you to upgrade from Windows 7
Jan 11, 2010 | Averatec 3200 Notebook
Someone messed with my Microsoft digital medial keyboard. Now when I make changes to my dual monitor display set-up the changes don't save and I must re-set them each time I re-boot. Any suggestions?
try backup all your important files then format your hard drive then install a new fresh install OS or windows then look if still the same
Hope it help you out
Jun 11, 2009 | Microsoft Windows XP Home Edition
Belkin FSD7050v4 driver for Windows 7
just installed my belkin wireless g usb adapter on windows 7 64 bit down loade driver from belkin right click run in compaterbilty mode windows vista service pack 2 and install
Apr 28, 2009 | Computers & Internet
Advueu Technology AMW-F196B Logo
224 people viewed this question
Top Advueu Technology Computers & Internet Experts
David Payne
David Payne
Are you an Advueu Technology Computer and Internet Expert? Answer questions, earn points and help others
