Question about Garden
David bradley chain saw.crank case#1050d - Garden
    Brigadier General:
  • 4,088 Answers
No problem indicated. Old brand saw.
Posted on Jul 08, 2009
How do I remove the motor from the casing of a husqvarna chain saw 240 model...?
On the 240 the case is part of the motor. The crank sets into the casing
emzrsqaaaabjru5erkjggg==rzzz8taejqosa5zvjombhz53ekoiikkk9uwfjkalhoziypiqiosj5ryukpkuglut6tgpiurveujr+oskqufvhkzkvsfevrlnwtbp8pj3aula2phc4aaaaasuvork5cyii=
Nov 10, 2016 | Husqvarna Garden
The motor is part of the casing on the saw. The crank shaft mounts into the case. To remove the crank shaft the case itself must be split.
http://service.webec.husqvarna.net/documents/HUSI/HUSI2008_AAaa/HUSI2008_AAaa__5069559-01.pdf
Where does the impulse line go to from the engine block.?
There are two "impulse line(s)" on a typical "2 stroke chain saw.
One goes from the intake or crank case to the carburetor to drive the diaphragm "pump". Sometimes this "line" is built into the intake or transfer port and back to the carb by passage ways drilled into each and mating thru the gasket. The pressure pulses drive the "pumper carb" to deliver the gas, whether the upside down, sideways or vertical.
The other impulse line will go from the intake or crank case (between the carb and crank case) to the chain oil reservoir to lube the chain.
The pressure pulses (pos or neg) will drive the very simple oil pump to lube the chain thru passageways and/or tubes between the "bar oil" tank and the engine case where the chain bar is clamped to the engine. There are crossing slots in the case and bar that allow oil to flow and the bar to be adjusted in/out to tighten the chain. An internal passageway in the bar from the crossing slot to the chain groove gets the oil to the chain. Always be sure to clean these passages with a copper wire periodically as they tend to get clogged with very fine wood shavings.
May 10, 2014 | Poulan Garden
I can't get the case back on the chain saw after chaning the blade the brake is to compressed how do i fix it?
There are a number of ways to do this, the easiest way is to remove the clutch and sprocket, the cover will then fit back on and you can use the handle on the saw to load it. the clutch is just spun onto the crank with a left hand thread, it can be jarred off against the compression of the saw.
Nov 14, 2012 | Husqvarna Garden
Does a homelite chain saw have a crank case youn put oil in homelite xl
Hi, it needs a two cycle mix at a ratio of 25 to 1 in the fuel tank and bar and chain oil in the oil tank. Hope this helps, regards Phil.
May 31, 2011 | Homelite Garden
How to crank the tyobi chain saw expander and make the chain saw move
You should be able to adjust the guide bar by loosening the lock handle and adjusting the cam to push the bar out to tighten the chain, If the guide bar is at the end of its adjustment the chain is stretched and needs to be replaced, as I understand your question.
May 21, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
I HAVE A HUSQVARNA CHAIN SAW AND I DONT WITCH MOD. IS IT .THE ONLY THING WHO WRITTE IS PR.YEAR 1997,HOW FIND THE TYPE OF THIS?
the model number should be on the crank rope housing or a sticker under they bottom of the crank case
Jan 20, 2010 | Garden
Stihl ms290 chain runs constantly even when idling and when u put the chain brake on it kills the saw
The centrifical clutch is probably rusted (or has a broken spring). You can try a small amount of WD-40 inside the clutch to see it that will break it loose.
Also, be sure that the chain tension adjustment is not too tight!!
Oct 10, 2009 | Oregon Scientific Oregon Chainsaw chain...
Garden Logo
230 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
