Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Wireless router belkin n1
I set a wireless network the using belkin n1 router the xbox 360 works on it the laptop works on it but the pc does not.the pc does pick up the neighbours network but not the router next to the base unit
  • stormshdw9 Dec 29, 2007
    I'm trying to connect an Xbox360 to a Belkin N1 router using the xbox wireless network adapter, it connects to the router but won't connect to Xbox Live.  I've tried making it a DMZ and also disabling the firewall but still nothing.
    Anyone have any suggestions?
    President:
  • 2,961 Answers
Right click on the network icon in your task bar and click view wireless networks, then when all the networks show delete them all and close the window, next, a pop up will say found wireless connections click the icon again and look for your connection in the list and click connect and enter the pass phrase
Posted on Nov 06, 2007
The router wont set up a wireless connection in the xbox so the internet does not work.
you need a wirless device to plug into the xbox 360 or u can use a long ethernet cable
Jun 27, 2010 | Belkin N1 Vision Router
I have a belkin -n1 wireless router.. it is a great router because it works all the way through the house. the only problem with it is that i cant update my xbox with it, neither by wire or wirless. if it...
first check whether the gaming ports for xbox have been forwarded in the belkin router or not....if not do it first....if you dont know the port numbers call xbox support and get the list of port numbers to be forwarded....
then enable DMZ for the ip address of XBOX in belkin router...
then enable UPNP in belkin router....
atlast Disable firewall in belkin router.... your XBOX will go online and GET UPDATE..... you can call belkin tech support of your country to assist you to forward ports for XBOX in belkin router... if you reside in USA/Newzealand/Australia/Canada you can call this toll free 1800 2 BELKIN(235546)...... or you can call my personal mobile... Im from India country code +91 Mobile number 9003593572
Apr 09, 2010 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 sony laptop media center problem
The firewall on your laptop may not work and/or you may need a software update either on the pc or xbox
those are the most common
your set up is ok
Sep 27, 2009 | Microsoft Xbox 360 Console
Belkin N1 Wireless router wont fully connect to laptop
if you connect your xbox and it works than it is not your isp
go to your network setup and try it with fix ip and DNS to you vista laptop wirless card /fixed card ip setup
goodl luck get back if this does not work with more info on your network setup
Jun 12, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin N1 router and xbox 360
You must configure NAT (Port forward) in the router.
Apr 14, 2009 | Computers & Internet
Xbox 360 router wont work with Belkin N1 Vision.
make sure u are looking for the right connection when the box opens for the connections on the left hand side u will c a small box click it u will get wireless /dialup/vpn just make sure you look for the right one also go onto ur computer into windows media into library options into sharing and search have your xbox on it will appear click on it to allow it to share with your pc i would appreciate it if you could rate this solution
Jan 02, 2009 | Belkin N1 Vision Router
My Xbox 360 Says No Wireless Network, 192.168 takes me to ask.com!
I believe you are referring to the network key set on the Belkinrouter. Since you do not have the code, you will have to access yourrouter's web interface.
Let's begin with your router:
Using your working laptop, open Internet Explorer type 192.168.2.1 (default IP address of Belkin routers) press Enter. It will ask for a username and password - by default it'sadmin for both. If it does not accept admin, type in the username andpassword you set to your router when you installed it for the firsttime.
Once you open the setup page of the router, go to the Wireless tab ofthe router (located on the left side of the web interface. Look forSSID and WEP key or Network key (SSID is the name of your wireless network). Take note of the SSID and WEP keybecause you will need to set this on the XBOX console.
On the XBOX:
Open the dashboard settings - select Network Settings. Configure your XBOX to connect to your wireless network. When it ask for the network key - type in the code that you will see on the router's web interface.
Try the steps I mentioned, give us an update and I'll reply ASAP if you need further assistance.
Good luck and have a nice day!
Sep 30, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My Belkin N1 and my xbox 360
I just got it and yes latest firmware as of end of mai has been downloaded
Jun 02, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin n1 wireless usb adapter
Dear Friend,
1. Connect your ISP modem to your PC and configure as Bridge mode.
2. Remove your ISP modem and connect your wireless router to your PC and configure as PPPOE mode. (refer http://www.wi-fiplanet.com/reviews/article.php/3645166 if any doubt on configuration)
3. Now connect your ISP modem to wireless router, The modem should connect to your WAN cable.
4. And Give the wireless router's IP in your laptop as Gateway (In TCPIP settings of your Laptop wireless adapter / or configure DHCP)
5. Now you can access internet on both systems.
Feb 02, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
XBOX Live problems with Belkin N1 router
I suggest setting this up with a WPA encryption rather than WEP encryption. This should get ya setup without a problem. Also, I've noticed live to be a bit buggy since Christmas. If you continue to have troubles after trying this call 800-4my-xbox. The recording will tell you if they are having network issues.
I bet this helps!
Dec 31, 2007 | Computers & Internet
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
202 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
