Question about Brother MFC-465CN InkJet Printer
Does not print properly-even after installing brand new cartridge
My hardly used printer Brother MFC 465(Hardly used but over 1 year old) with fresh new ink cartridges will not print properly. Colour pictures are distorted,and will not print black ink at all
  • 526 Answers
Most likely your ink nozzles have clogged up.
try several cleanings, if it still does not work, you probably have to get the printhead replaced.
Posted on Jun 26, 2009
After cleaning it does not print blak colour it print other colour
Sir/Madam
I Think Your Brother Printer Ink Cartridge is Not Install Properly Or You Do Not Have Ink In It,So Contact Your Brother Printer Ink Cartridge Dealer,Or Buy Ink From Offical Brother Printer Website,Or in case You Still Having Brother Printer Problem Then Follow Us For On: Brother Printer Support
Jan 22, 2014 | Brother MFC 6490CW InkJet Printer
Paper jams brother mfc 7420
Paper Jams are routinely caused by bad roller in the printer. The Heat of laser printers can render these rubber roller pretty useless in a couple of years or less if you print often. If you have recently replaced the drum (according to the recommended print output number), Then If an $80 dollar roller + labor is worth it to you, go for it, otherwise buy a new printer and Brother gives the best ink value per page. hope this helps.
Jan 28, 2013 | Brother MFC 7420 All-In-One Laser Printer
Black ink won't print with new cartridge installed, and while cleaning the print head the colour cartridges show as not installed or recognized.
If less than 1 year old contact Brother. Printhead and/or ink refill assy are faulty and should be repaired freeunder warranty ;)
Nov 30, 2010 | Brother MFC 490cw Color Inkjet...
Brother MFC-290C not printing black
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Jun 25, 2010 | Brother MFC 420CN All-In-One InkJet...
Brother mfc 5840 won't print clearly
you need to check the maintainence kit and see if it's full. Also if it isn't, use some iso-proponal alcohol and some q-tips to clean the print section of the cartridge and the cartridge tray.
Aug 21, 2009 | Brother MFC-5840CN All-In-One InkJet...
Replace black ink in brother mfc-465 inkjet & now it won't print
are you using brother oem ink? you ,may check and see if the seal is still on the cartridge, if not try and take a paper clip and insert it in to the air hole on the catridge, some times it gets clogged up. brother tech
Jan 13, 2009 | Brother MFC-465CN InkJet Printer
Use MFC-465CN withou cartridges
in order to scan you need to have ink in cartridges?... great design!!! cheat the printer - use black electric tape to cover transparent slots at the back of your cartridges (printer will think that it has ink and it should stop that annoying beeping)
Aug 05, 2008 | Brother MFC-465CN InkJet Printer
Brother hl 4050cdn - the colour cartridges all run out together even though I've printed hardly any colour
The fluid component of the ink will evaporate if the printer is in a hot dry environment. Loss of ink over time should be anticipated.
Jun 20, 2008 | Brother Office Equipment & Supplies
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-465CN InkJet Printer Logo
474 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
