Kenmore washer model no. 110.26904692 I am replacing the Dial and guard timer and can not remove the knob. How do I get the knob off?
  • 5,911 Answers
With the knob pulled out, rotate it counter-clockwise. If that doesn't work, rotate with the knob pushed in (I can't remember which position it should be in, but do know that it comes off by turning it counter-clockwise). With the knob off, the dial guard should lift off the center post of the timer.
Posted on Jun 26, 2009
I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
Good day Mr.james dant..
Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
Instructions
1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
9. Place the dial back onto the timer post and then screw the knob onto the post.
10. Plug the washer back into the wall outlet
Try to watch this video:
Nov 25, 2011 | Washing Machines
How do you replace the timer in a Kenmore Washer Model 22622?
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=41610396bdeaf9d724c8d6b9910df259
Basic Whirlpool / Kenmore washers may use one of two different timers. See the following Whirlpool / Kenmore Service Manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Assuming that you have the metal timer, You'll need to remove the timer knob. The easiest way is to hold the metal shaft that passes through the timer with a thin needle nosed pliers while un-screwing the knob.
Once the knob is off, it's a simple matter to unplug the connectors and remove the bolts holding the timer to the console.
Oct 21, 2010 | Kenmore 22622 Top Load Washer
How do I remove the timer dial on a Kenmore washer model 26632500
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26632500&pathTaken=partSearch
Next, see the following for how to release the console and cabinet if necessary:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=2ad8dd748a52b13f53044e4341dfb53e
Then see the following Whirlpool / Kenmore Service manual for top load, direct drive washers.
The dial on models with a metal timer has to un-screw from the timer.
When we were replacing ours, we found that we had to hold the back of the shaft that goes thru the timer with a thin needle nosed pliers in order to keep the shaft from turning while we un-screwed the knob.
Jun 10, 2010 | Kenmore Washing Machines
How to install 3949238 in kenmore model 110.26912691. I have unscrewed the control panel, but the brass hinge wont come out
First, see the Sears parts site for your washer;
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26912691&pathTaken=partSearch
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
In order to replace the "dial" you have to release the console by snapping off the two end caps, unscrew the two phillips head screws, and pull and lift the console.
It should lean back and balance on the hinges.
To release the dials from the timer, you may have to hold the metal shaft on the back of the timer with a thin needle nose pliers while you un-screw the knob.
With the knob off, the dial simply pulls off.
May 28, 2010 | Kenmore 22642 Top Load Washer
Wash cycle knob turns without controlling wash cycle
it's possible go to www.repairclinic.com and enter the numbers you have posted and it will show you what they are. I have the same problem. What I did was not pretty but it works for now. I broke a piece off of your part#387997 and simply turn my dial that way and then pull the center out to start the wash. Considering a new timer is close to $100+ and it works fine this way , well you know...
Apr 06, 2009 | Washing Machines
Kenmore Series 80 Washer timer knob spins
Something in the timer came apart. Timer needs replaced. When in good working order, the timer should ONLY ever be turned clockwise..Reversing this could break it.
Mar 11, 2009 | Kenmore 24032\24036 Top Load Washer
How to remove knob from panel
If there is a black tab on the back of the timer, it needs to be pulled out of the timer before you can remove the knob
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Can not get the upper right dial off. It needs to be replaced.
remove console by taking 2 screws from the rear of it out, timer knob can be removed by squeezing pin at the center of the timer and pulling knob forward. Probably the timer needs replacing
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
Apr 17, 2017 | Kenmore Washing Machines
RRemoving the washer starter dial
Yes, stop pulling on it. Axcess the rear of the timer there will be a smaller hole with a black piece of plastic inside where the knob shaft would be if it went all the way through. use needle nose pliers to grab the plastic piece and pull out. it is easier if the knob is pushed in is gets recessed a little more when you pull out the knob. The new timer comes with a new plastic piec pull it out then push back in to lock on the knob again.
Nov 23, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
159 people viewed this question
Top Washing Machines Experts
