Question about Tascam 2488 Portastudio Multitrack Recorder System
Tascam DP-02 Error message is No Free Disk when I try and master a vocal performance about 4 minutes long. System shows song is 432 megs I have a 1 Gig Card formated with a FAT Partition at 1/2 Gig
  • 189 Answers
SOURCE: vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Cheers.
bd.
Posted on Sep 15, 2008
  • 189 Answers
SOURCE: Can't import song from PC to DP-02 Unit and the Manual STINKS!!!!!
You shouldn't have to do any formatting. If you copied a wav file onto the DP-02 while connected with the USB and with the USB connection open, then you were already accessing the fat partition. One thing to be aware of is that the DP-02 only works with mono wav files. So if the wav file from you PC is being saved as a stereo wav (which is the default for most programs) then you'll have to specify mono instead. The DP-02 only works in 16 bit as well so on your PC you should be saving and wav files you wish to import as 16 bit, 44.lkHz mono wav files). That should be about it.
Hope this helps.
bd.
Posted on Oct 09, 2008
  • 189 Answers
SOURCE: Unable to record or playback on new DP 02
It sounds like either the inputs are not assigned or the tracks are not armed for recording (or both).
Here is a quick explanation of the procedure involved in recording with the DP-02 that I posted for another person who was asking for some basic instruction on how to record. You might be missing a step somewhere along the line as for instance you will still see the meters move even if you don't have the inputs assigned or don't have any tracks armed, but the DP-02 won't record anything until you do both.
To record you need to first assign your input to a track, then arm the track for recording, and then press play + record at the same time.
1. So you would patch your mixer output, mic or instrument into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
2. Then to assign that input to a track simply press and hold the 'input A' button and then press the 'rec' button of the track you with to record on. The 'rec' button will flash rapidly to indicate that the input is assigned to the track.
(To assign the input to a different track you have to clear the input assignment from the first track and assign the input to a new track. To clear an assignment press the input assign key, A in this case, and the track it's assigned to will flash its 'rec' button. Hold down the input assign key and then press the flashing 'rec' button. The button will stop flashing and the input can then be assigned to another track by following step 2 again).
3. Next, to arm the track for recording simply press the 'rec' button for that track. The 'rec' button with flash slowly.
4. To begin recording press play + record together in the transport section and the 'rec' light for the armed track will stop flashing and light steadily. Press 'stop' to end recording.
This should get you started. The operation of the DP02 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Hope this helped.
Cheers,
bd.
Posted on Nov 26, 2008
  • 189 Answers
SOURCE: Tascam DP-02CF: How to transfer files to my computer?
You can't see the fat partition from within the DP-02. It's there, but only your PC will be able to read the contents of the fat partition when you have the USB 'opened' on the DP-02. The manual states that if your CF card is less than 5 Gb in size than you will only see/be able to select one partition. The default CF card that comes with the DP-02CF is only 1 Gb.
If you've created a backup or exported your wav files properly and everything is working ok with the CF, then you should be able to see backup or wav files showing up in the fat partition while connected to the PC. Even if nothing is backed up or exported you should still see the directory structure from your PC with the three folders, BACKUP, WAVE and UTILITY. As you are not even seeing these directories, what may have happened is that the fat partition had become corrupted or these folders had gotten erased.
I would have thought that reformatting the FAT partition would have fixed this problem however and that the DP02-CF would automatically recreate the required directories on the CF media after a reformat. The manual is unclear on this however.
So a couple of things you could try:
1. You describe opening the USB connection as 'push the USB button and then hit enter'. I was assuming you meant that you were selecting 'usb' from the menu and then pressing the 'enter' button to open the usb connection. You may wish to verify that the usb connection is being opened properly first.
2. If the connection is opening ok, and after a reformat you still aren't seeing any folders in the fat partition while connected to your PC with the usb open, you might wish to try to recreating those directories in the FAT partition yourself. While accessing the FAT partition (DP-02CF's removable drive) from the PC create the three directories exactly as named in the manual (WAVE, BACKUP, UTILITY). If that works, disconnect from the PC, try exporting a track or backing up a song again, and reconnect to the PC to see if you can see/access those files now.
Best of luck.
bd.
Posted on Jan 02, 2009
  • 15 Answers
SOURCE: I've been exporting master tracks and now I've
If you NO LONGER NEED the songs/data in the FAT partition, you can delete the entire contents thereof in the manner detailed below. Note that these instructions were taken directly from the Neo manual.
1 With the transport stopped, from the DISK menu, highlight FAT REFORM, and press YES/ENTER.
2 A pop-up message appears.
3 Ask yourself once more if you want to erase all the data on the FAT partition. Press YES/ENTER to continue with the operation when a pop-up appears, or press NO/EXIT to halt the operation.
4 When you reformat the FAT partition, four directories (folders) named WAVE, SMF, BACKUP and UTILITY are automatically created. These folders are used for audio files, Standard MIDI Files (SMF) and backup data and system utilities, respectively.
...this will reformat and thereby EMPTY the contents of the FAT partition and create the 4 new, empty files as listed above.
THINK before you do this though, and I hope this helps.
Posted on Feb 28, 2010
How do I import a CD created on the Tascam DP-02 into the Tascam DP-32?
I have the Tascam DP-02 it uses a fat 32 partition, Fat 32 partitions are pretty much obsolete replaced with the New Technology Filing System or N T F S for short. Using the DP-32 systems software try plugging the DP 32 in to your computer once the software for you new unit loads locate and open the fat 32 system folder I'm not sure if the DP 32 uses the same fat 32 partition, But if it does the fat 32 folder should be there, Locate and open it you should then be able to move or delete your recorded material as desired
Oct 04, 2014 | Tascam DP-32 Portastudio 32trk Digital...
I have a standard DP 02 (non cf) and I want to add vocal tracks to a previously recorded song (tracks 1 and 2) and I don't get any sound from my mic. The mic/line/guitar switch is set to mic/line but the...
you have to make sure the song tracks(1 &2 ) are not armed. then you can assign your vocal to any of the other tracks. after you do this , make sure you arm the track. you should be able to hear your mike.
Apr 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
Is there a driver for tascam dp-01 for windows7 operating system
Unfortunately no such driver is available, because tascam have discontinued that particular model.
Here is a way to get your recordings off the device
On the Tascam main menu, select "Wave." 2) On the Wave menu, select "Export Master." This saves your mastered song to the correct folder. 3) Connect the Tascam DP-01 to your computer. You will get a message telling you your USB device has malfunctioned. 4) On the Tascam menu, select "Disk." 5) On the Disk menu, select "USB OPN/CLS." Your computer should detect the DP-01 as a hard drive & be visible in "My Computer" on Windows.
Apr 03, 2011 | Computers & Internet
My tascam dp 02 started up with this mount error message I bought a tascam dp 02 for my son for christmas. When I plug it into the mains the display shows ' mount error :oc /please pwr off'. my email is...
The TASCAM DP-02 Owner's Manual has no reference to a mount error in it. There are many people online complaining about mount errors on their computers, mac and win, when hooking the tascam up via USB, but your post suggests this error was on the DP-02 itself, is that correct?
I get less than a dozen hits of people asking this question online, and absolutely no useful answers or responses.
Do you have the DP-02CF model? If so, it may be a faulty CompactFlash Type I card that it is trying to mount. If there is a disk in the drive, I'd remove that cd in case it is trying to mount a bad disk.
I can most likely help troubleshoot a troublesome USB-to-computer connection, but otherwise I'm going to have to refer you to TASCAM customer service, (although I must say the forums I've perused have little positive to say about them.) TASCAM support in the UK (a guess, but you did use the term 'mains' in your post) is provided by TEAC UK Limited at +44-8451-302511 or www.tascam.co.uk.
Best of luck & I hope that helps.
Dec 26, 2009 | Tascam Dp-02cf Digital 8-track Recorder
How do I split up one song on a Tascam DP-02 into more songs?
Hi, I think the proper way to do this should be to copy and paste a section of the track using in and out points to mark the section you would like to copy on to another track but I have been unable to figure this out! very frustrating! However for now I have managed to do it this way (The long way round but it works) say a track that I have 10 or so songs on, I copy it say 10 times (this takes a long time!) When you copy them they show up as the same title. I then rename the original so that i don't mess about with the original! Then I set in and out points previous to the song I want to get to another track and press cut. I then set in and out points after that song and press cut this leaves you with just that song and it is at the begining of the track because cutting closes up the gap. I save and rename this appropriatly. I then do the same for alll the other songs I want with the other copies.!!!!!! Hope this helps, if you work out how to cut and paste please let me know!
Nov 11, 2009 | Tascam Dp-02cf Digital 8-track Recorder
I cant record
You'll see this message if you try to create a song but there's not enough disk space on the partition to create a song. Free up some disk space and try again. The manual is at http://www.tascam.com/products/dp-01;9,16,33,19.html under resources.
May 30, 2009 | Tascam DP01 All-In-One Recording Package...
Peavey PV14 to Tascam DP-02
The usual setup would be to use the main outs to your Tascam as the master faders control the levels there. The control room outs are more geared towards monitoring and are tied to the headphone outs level control.
Apr 20, 2009 | Tascam 2488 Portastudio Multitrack...
Just bought a DP-02 w/40gb hard drive
You'll first need to find some aux audio out jacks on your karaoke machine. You might need an adapter, but the basic idea will be to connect the aux out from the karaoke machine to an input on your Tascam DP-02.
Then on the DP-02 you need to assign whatever input your plugged into to one of the 8 tracks. Let's say you're using the left input (input A) and want to put the karaoke music on track 1. You'll press the 'Assign A' button on the DP-02 and while holding it then press the 'Rec' button of track 1. The 'Rec' button will flash rapidly to show its been assigned. (for reference: assigning an input is better described on page 23 of the manual). Then you'll want to arm track 1 to record. Press the 'rec' button for track 1 and it will start to flash slowly to show it has been armed for recording. Now you are ready to start recording. On the DP-02 press the large round play and record buttons on the lower right together to start recording and start your karioke machine playing. When the song is done press stop on the DP-02.
Now to record your vocals you'll need your mic to be plugged in (lets' say it's in input B). You'll need to assign this input to a free track (track 2). Press the 'Assign B' button and while holding it press the 'Rec' button for track 2 (rec button will flash rapidly). Then you'll want to un-arm track 1 and arm track 2 for recording. To do this press the 'rec' button for track 1 so that the light goes off and then press the 'rec' button for track 2 so that it flashes slowly.
So now when you press play and record together to record, you'll hear track 1 playing (the karaoke track you recorded earlier) and you'll be recording vox on track 2. Of course you'll also be recording whatever you hear in the room onto track 2 along with your singing, so in order to get a clean recording there (prevent bleed) you'll want to plug some headphones into the DP-02 and listen to those as you record.
That's pretty much all there is to it. Some variations if you wish to record the karioke in stereo vs mono (I gave you the instructions for mono here), and you may need to turn on phantom power if you have a non-powered mic, but the idea is basically the same.
Hope this helps.
Good luck.
bd.
Oct 24, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DP-02 error 50:0
this happened to my dr-1 what i did is took out the SD card, used a card reader to put all the songs from the music folder onto my laptop, then erased the songs from the card, reinserted it into the Dr-1 and no more error.
hope it helps. tascam doesn't come with a card reader, they use a usb but i've found that a card reader is faster and easier to manage. you can get one anywhere they sell electronics for about $15. cheers
Mar 16, 2008 | Audio Players & Recorders
Tascam dp-01fx system 50 error
what the above guest said is exactly what you need to do. Make sure of course there is nothing on your FAT(previously exported songs/masters) because they will be erased. just go to menu->disk->fat reform, then press enter
Nov 07, 2007 | Tascam DP01FX All-In-One Recording Package...
Tascam 2488 Portastudio Multitrack Recorder System Logo
187 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
