This sounds like a common issue. The boot manager file "NTLDR" Can become corrupt or go missing due to a few situations.
1) Shut down improperly
2) Virus
3) Bad hard disk
4) Windows being windows.
Too fix this simply use a windows 7 cd and boot from it.
Choose the Repair option and let it do its thing. If i recall there's also a repair startup option you can use aswell.
Windows repair usually fixes the problem but if that doesnt work you can also put the hard disk into another computer and copy over replacement boot loader files.
Try that. The windows repair usually works but if you have to use the alternative and it doesnt work it could be your MBR. Windows repair also fixes this but theres an old command you can run from the dos shell of the cdrom "mbrfix or fixmbr" That will take care of it.
Good Luck :)
SOURCE: driver for HP Pavilion DV6 for Inbuilt webcam Driver
Go to cyberlink.com download driver, you can also use Skype. Just remeber to check what version you have, this should be found in the manaul. Hope this helps
SOURCE: Low volume on my HP Pavilion dv6-1245
Open the audio panel (settings -> control panel -> Sounds and audio devices -> volume). Check that the volume slide is all the way to the right. Also, click on the "speaker volume" button and check it is all the way to the right
SOURCE: i am using the HP pavilion dv6 314-1se series
Hi Sir/Madam;
I have provided the source link to download the driver for your HP Pavilion dv6 314-1se.
But as to inform you, your notebook is not designed for Windows XP or any other Older
vesions of windows. The driver which you will download from the source link has the support
for Windows XP. Let me know if the problem persists.
Click here to download
IDT
Thank you for using FixYa.
SOURCE: I don't know where the wireless button is
The WiFi indicator is also the button. It's to the right of the volume control And above and between the f11 and f12 keys.
