I have a ford winstar 98 the front ac works fine but got stock in just one posotion the rear one blows just hot air.
Hi Riverplate....I also have a 98 Windstar, and it did the same thing....Its an easy fix!...Its the knob/controller on the dash (the one that you turn to either select Heat by going clockwise, and A/C by going counter clockwise)...It just takes a few minutes to remove the plastic housing surrounding the controles...then that whole knob unplugs and you plug in a new one.....I replaced mine a few years ago with a used one and that did the trick....Its actually just started to act up again (blowing heat at rear floor from time to time when wanting a/c in rear roof) so I think I will go with a new switch now as well......good luck deweronick@hughes.net
Posted on Jul 31, 2009
Passenger side blows cold air--what part could it be
2001 Chevy Tahoe Heat Problem - Tahoe Forum
www.tahoeforum.com > ... > Technical Discussions
Dec 5, 2008 - 10 posts - ‎7 authors 2001 Tahoe, the front heater blows a little hot air when the car warms up and then blows cold air. The rear heat seems to work fine. I changed ...
Rear AC blows hot air - Tahoe Forum - Chevy Tahoe Forum
Jul 14, 2008 - 10 posts - ‎5 authors
On my wifes 03' Yukon the rear air conditioning blows hot air no .... Pull the panel off and look at the hot/cold actuator shown in the picture.
Oct 30, 2015 | 2001 Chevrolet Tahoe
My gmc yukon 2000 slt rear ac blows hot air when i have ac . on and the front works fine .
I have a 2000 GMC Savana Van SLT with front and rear AC/Heat. My front would blow hot while the rear blew cold with AC on. It turned out to be low on Freon. It's hard to know if you have the right amount of freon installed because pressures vary depending on the ambient temperatures. So the best way is to remove all the freon then reinstall the recommended amount as listed on the evaporator housing near the firewall. This worked fine for me... works like new after installing the correct amount of freon.
Jul 01, 2014 | 2000 GMC Sierra
Where is the expansion valve located? The air conditioner is blowing hot air in front and rear units. I did put two cans of fr-ion.
Is the system full of freon ?
The rear ac uses an expansion valve, and the front ac uses an orifice tube. One system can work independently of the other.
Sep 04, 2013 | 2002 Ford Excursion
No rear air but blows good
if the front ac works well but the rear is hot check to rear control switch located in the front ac control head.
it has a vaccum-electrical switch and these go bad often
Aug 05, 2010 | 1999 Ford Windstar
I have a 2003 ford winstar and i'm having problem with the front heater. It blows cold air , the rear one works fine. What could it be?
THERE IS A DAMPER THAT IS NOT OPENING TO THE HEATER CORE TO LET THE HEAT IN THIS DAMPER SHOULD BE UNDER THE DASH ON THE PASSENGER SIDE
Sep 23, 2009 | 2003 Ford Windstar
1988 Ford Exppedition heater in the front will not work
I ASSUME THIS IS A 98, THIS PROBLEM IS CAUSED BY A PART CALLED AN "AIR TEMPERATURE CONTROL BLEND DOOR ACTUATOR MOTOR" THIS MOVES A DOOR BETWEEN THE COLD AIR FROM THE AC AND THE HOT AIR FROM THE HEATER CORE, YOU WILL NEED TO REPLACE THAT ACTUATOR. .
Sep 05, 2009 | 1998 Ford Expedition
I have rear AC that works perfectly, but the front AC only blows hot air what do i do to fix it?
replace the temp door actuator motor,it is up under the dash ,a flat square block looking thing with 3 screws holding it on u will see two the one u need to change is usally on the bottom
Jul 06, 2009 | 1999 Ford Expedition
Rear airconditioner blowing hot air on 1998 ford windstar,front works fine
check to see if there is enough freon in the system,if so eplace the rear expansion valve
Jun 30, 2009 | 1998 Ford Windstar
Have a 2000 ford expedition and the ac in the front blows hot but the rear ac works fine. what could it be
Listen and see if the vent flap is moving from the hot position, to the cold position. If that's working then the evaporator may be clogged. It sits inside the same box that the heater core is inside of and if it becomes clogged with hair or dust, then it wont allow the blower to blow through it. But it would then bring hot air through the vents because the heater core is there too.
Jun 15, 2009 | 1998 Ford Expedition
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
