Question about Craftsman 24 Hp 48" Deck Yard Tractor
My dyt 4000 Model # 917273620 won,t stay running when I release the Clutch. What could be causing this?
  • 127 Answers
SAFTEY SWITCH IS MALFUNTIONING ON THE DECK OR UNDER THE SEAT
Posted on Jun 26, 2009
Polan 14.5 rifding mower won't stay running when clutch released
Either a problem with the seat switch, or just make sure the block connecter that gose to the switch is fully pushed into the switch if its even slightly off it will stop the engine.
Jun 17, 2012 | Poulan Garden
Can't figure out where to hook the idler spring onto the mower deck on my DYT 4000
look at the picture on the bottom of the foot rest there is a picture there
May 18, 2012 | Garden
My Craftsman 4000 dyt lawn tractor's electric clutch went out and when it locked up it choked the motor down....now everything is dead, there is not and "juice" going to the starter, the headlights will...
Sounds like the machine stopped charging,usually caused by a faulty rectifier/regulator or a bad connection to it.Try either charging the battery for an hour or so or you can put booster cables from your car to it and then if everything is ok you need to fix the charging system,or replace the battery[once they are sulphated they will not take a charge even if the charge system works].Check the connections to the battery as well and if you can test the tractor when it is running and see if the voltage stays between 14 and 15 volts.Let me know how you make out.
Jun 12, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman DYT 4000 riding mower: Last year I notice the mower has lost some power. Going up hill and blowing the grass back to the bag catchers. I installed a new carburetor, magneto, fuel filter, higher...
your valves might be sticking due to old gas when you had some or the little rod clutch rod to the carb is disconnected this is just to choke it before it dies out.
I sugest that you clean out the carb out with carb cleaner and also clean the valves.
Mar 29, 2010 | Water Heaters
I have the DYT 4000 model. My tractor will start
SOUNDS LIKE YOU HAVE ONE OF YOUR OTHER SWICHES ARE BAD LIKE THE SEAT
Sep 29, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
What engines will fit craftsman dyt 4000 (18.5 blew w/ 290 hours)
Hi there
The only thing you have to do is have the size (diameter) and lenght (from cranckcase to end of shaft) of the shaft you have on your b&s and just go to your local Honda dealer , give them your shaft size and they should be able to give you all the options for a brand new motor . I really believe you can get a Honda 20hp model GXV620 or a 24hp model GXV670 that will replace your B & S motor .
Hope this help .
Sep 01, 2009 | Garden
Replacing the blades on a craftsman dyt 4000
Not a hard job, but you will need a couple of tools. First, you will need a wrench that fits the nut that is holding the blade on. I prefer a closed end wrench, but an open end will do. Second, you will need a blade changing tool. The brand name is called a Blade Hog. It attaches to the deck and holds the blade in place so you can turn the nut. Raise the deck as high as it will go, attach the Blade Hog, and then loosen and remove the nut. Be sure and pay attention to which side is up on the old blade and put the new one on in the same manner.
hope this helps,
c
Sep 21, 2008 | Craftsman Garden
Craftsman 24 Hp 48" Deck Yard Tractor Logo
606 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
