Question about Tools & Hardware - Others
No fuel pressu on 35hp vanguard after engine reaches operating temp
  • 1 more comment
  • eshockley473 Jun 26, 2009
    Was there any recall on fuel pumps?
    No fuel coming from new fuel pump on Briggs and Stratton 35hp, Model M613477
    engine not a vacuum fuel pump but a mechanical. any other suggestions?
    Sergeant:
  • 353 Answers
Change the vacuum hose from engine to fuel pump
Posted on Jun 26, 2009
  • gerald darling
    gerald darling Jun 26, 2009
    check for a collapsing fuel line
    President:
  • 828 Answers
Open the vanguard to make the air out first. and make possible empty it and put back again the fuel.
Torque for oil pan on 16 hp vanguard
You should not need torque on those bolts..just need only a few lbs..enough to sets the gasket tightly...I use a small hand wrench and tighten hand tight holding the wrench at the head part of the handle..this will give you plenty of torque without fear of stripping the threads..if you want, re tighten after the engine warms up to operations temp..just a suggestion how I have done it successful many times..good luck..
Apr 26, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Why is my cadillac 4.5 engine smoking
What color smoke ? Blue = oil burning , black = too much fuel (rich) white = coolant - blown head gasket ,cracked head or block . White also could be caused fuel running through the engine , no combustion !
What Your Exhaust Smoke Is Trying To Tell You
Stuck Open Fuel Injector how to fix
Jun 13, 2017 | Cadillac DeVille Cars & Trucks
Engine balks and quits after reaching normal operating temp.
sounds like a fuel problem , water in gas , ......
Mar 09, 2010 | 1993 Chevrolet K1500
Engine will not go over 4000 rpms when under a load
Check the fuel pressue.
Check the mass air flow meter.
Apr 01, 2009 | 1999 Hyundai Accent
Very bad idol and run condition.
sounds like a possible water temp issue... check your thermostat and/or water temp sensor. when you first start your engine the computer uses the water temp reading to do a 'cold start' scenario, more fuel. once you reach normal operating temp the fuel should be cut back. if the thermostat is not opening and closing properly this can cause strange readings from the water temp sensor (which is mounted near the thermostat)... unlikely the sensor is bad, but a possibility... more likely the thermostat.
Mar 23, 2009 | 1993 Ford F150 SuperCab
2000 chevy blazer starting issues
swng,
1) Is the service engine soon light ever on when engine is running?
2) Per your description I would look at the ECT sending unit. It sends coolant temperature information the the Engine Control Module for proper fuel delivery for cold engine start. It may have lost its calibration.
Let me know.
Regards,
Feb 24, 2009 | 2001 Chevrolet Blazer
Tools & Hardware - Others Logo
65 people viewed this question
Top Tools & Hardware - Others Experts
Bill Boyd
ray gallant
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
