Question about Nintendo Video Game Consoles & Games
Remote dont work. lights just flash. tried to sync did not work. Bought a new remote and went to sync it now it is doing the same thing the other remote did> Any suggesions?
  • mal27harris Jun 26, 2009
    I will try a new sensor bar!
Basic Question: Did you set up the sensor bar?
I'm assuming you follow the instructions to plug in the Wii and to attach the sensor bar to the console and position the sensor bar so it is either below or above the television.
The Wii remote flashes (more specifically the bottom row of four lights that indicate which player each remote belong to flashes) when a button is pushed on the control while the Wii is off.
If the Wii is on and simply sleeping (as evident by a blinking yellow light on the power button on the console) pushing the power button the control should turn on both the console and the remote. Be sure to aim the remote at the console when "waking" the Wii up and at the sensor bar once the Wii Menu loads. The remotes automatically turn off with lack of interaction.
To recap: Your remotes sound to be working fine. I would assume it might be a problem with the interaction between your console and the remotes or the setup of the console. The Wii Information Guide has pictures and pretty clear connection instructions that should help fix your problem.
If everything is set up correctly as per the instructions and your system still does not interact your sensor bar may be faulty or your console as I believe you're remotes work fine.
Posted on Jun 26, 2009
Bought a new will remote but it doesn't work.
Check the battery levels. You can do this by pressing A. If all 4 lights flash on and off, your batteries are completely charged. 3 lights, 2 lights, and 1 light signify 3/4, 1/2, and 1/4 battery levels. If lights don't flash, replace/insert batteries.
If it's not working with your console, open up the battery cover and the flip lid on the front of the console. (If it's a Wii U, you don't need to open the flip lid.) In both places, there is a red button. (On Wii U, it's next to the flip lid.) Press both red buttons at the same time. (Your Wii will need to be powered on.) The Wii Remote will continuously flash lights until it either receives a sync signal or about a minute has passed; whichever comes first. If you've pressed the buttons and your remote is still flashing, press the button on the console again. Once the remote is synced, the flashing lights will turn into a single light; the placement of the light will vary depending on how many remotes are signed into the Wii.
*Note* Once your remote is synced, you simply need to press A to sign back in if your remote turns off.
If all of the above steps were followed, and your remote is still not functioning, contact the manufacturer. Brands such as Nintendo and Nyko are usually okay, but generics like GameStop aren't the best. It's often easiest to return it and buy a different brand.
Apr 29, 2014 | Nintendo Wii Console
My Wii is not working. It will come on but the remote will not sync with the console (the hand does not appear on the scree). We purchased a new remote but it still is not working. We pushed the red...
You will have to update the wii to play newer games. Your controller problem if it does show a led light on the remote then its synced. If its just not showing you a hand on the screen then its probably your sensor bar. If your controller will not sync and all four leds flash then I would push the button on the console and push the button the remote then just try hitting the a or b buttons. I've also had to slap the remote after hitting the sync buttons to get it to sync. The update thing is normal though.
Jan 10, 2011 | Nintendo Wii Console
Hey I recently just bought the SO32 helicopter and am having trouble getting it to work. The helicopter is charged and the lights on it are flashing, but when I turn the remote on, the power light is...
The problem is the battery, I just got one for Christmas and overcharged the battery. I put a new one in and it works. The manual says never charge over 90 minutes.
Dec 25, 2010 | SYMA Toys industrial Syma S032 Ready to...
The Sync button wont make the drum light spin
I have the same problem. On my xbox, I traced the problem all the way to a poor solder connection under U2C1. This is also the cause of a more cosmetic issue with my console where the console does not know its orientation.
All is not lost though. You can force the console to sync using a play and charge cable. I bought one from Best Buy today for $15 and was able to get my wireless remote to sync instantly. The connection was maintained after I unplugged the cable.
Aug 04, 2009 | MTV Games Rock Band Bundle for Xbox 360
Brand New Wii Remote not working
tracey.....take the battery cover off the back of the remote....then go to the game system cons and open the front flap to the left of the cd slot (find the red sync button on the cons......press and hold the red sync button next to the batteries on the remote......now just press the button on the game system (do not hold button on the cons.)....watch the remote led lights on the bottom....when they are done blinking there should be a light left on (if this is the second cotroller, it should be the second light from the left that is on).
Dec 25, 2008 | Nintendo Wii Console
Wii remotes not working
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide,that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
May 10, 2008 | Nintendo Wii Console
Wii Remote Control Stopped Working
This happened to my son. I did some reading and found out you have to resynchronize the remote. This is from the manual
1) Press the Power button on the Wii console to turn it on.
2)Remove th battery cover on the back of the remote and press the SYNC. button inside the cover. The Player LEDs will blink.
3)Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment
4)When the Player LED blinking stops,connection is complete. The LED that is illuminated indicates the player number.
This procedure must be followed for each additional Wii remote added to your system.
This worked for me, hope it helps you.
Jul 04, 2007 | Nintendo Wii Console
Video Game Consoles & Games Logo
520 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
