Question about PANDIGITAL 8.0" Digital Photo Frame (PAN802)
Frame only flickers - PANDIGITAL 8.0" Digital Photo Frame (PAN802)
  • 6,784 Answers
Try pulling the battery for five minutes. if it is plugged in a wall socket, pull the plug for five minutes. once the five minutes are up, power the unit up again and, test the display. if it continues to flicker, you will need to delete all loaded pictures and, reload them at this point. this could be a overloaded memory module.
If the reload doesn't work, this will confirm a display board chip issue. you will then need ot send this device in for the repair.
Posted on Jun 26, 2009
How can i delete all my pictures from memory frame all at once?
Posted on Jan 11, 2010
Artic cat 2003 mountian cat 800
Assuming all wire harnesses are stock and loomed from the factory it sounds like a frayed power wire making contact to your frame somewhere. Chasing wiring is never fun. Start from the headlamp bucket and work through them looking for fray or broken wire loom. Could be a lead touching the frame or ground wire connection somewhere in its path. Sometimes its as easy as within the headlight bucket itself. Goodluck
Dec 18, 2013 | Suzuki Motorcycles
Lights flicker while driving
bad electrical connection somewhere, check all grounds espically from battery to frame. Check for a ground from lights to frame or body. Bad connection somewheres, might be one of the "search till you find it" type repairs.
Dec 16, 2013 | 2001 Chevrolet Tracker
PANDIGITAL Digital Photo Frame works perfectly except the SCREEN Flickers Black after a few moments
Annemarie, I had a similar problem with an off-brand photo frame from Wal-Mart last year, although in my case the frame would shut down entirely after it had flickered a few times. In my case, I was able to remove the back of the frame's case by removing 4 screws (two were hidden underneath model number stickers) and inspecting the device's innards... what I found was that, as you surmised, there was a loose connection from the female end of the DC-in power supply. The ground connection to the device's circuit board had been poorly soldered, leaving the connection itself loose and a small piece of solder on top of the board and very near the positive connection.
While not being the best solderer in the world, with the aid of a magnifying glass, a solder removal tool, and a ColdHeat soldering wand, I was able to heat the offending piece of solder and remove it from the circuit board and then, as I was personally uncertain of my ability to re-solder the connection without melting the board, I simply held the connection in place and applied a dab of hot glue to keep it there. After the glue cooled, I reassembled the case and the frame worked for almost another year before something else finally burned out and it was left cold and dark.
Hope this helps, good luck!
Dec 03, 2013 | PANDIGITAL 7-Inch Digital Photo Frame with...
I have a 2001 Nissan Xterra and the light flicker and abs light flickers when i hit bumps in the road what could be the problem?
It sounds like a loose ground wire, which one, I can't tell you. If its in the dash, there are ground wires connected to the car frame. You probably find it by looking under the drivers dash. It will be a wire connected to the frame by a screw or nut. Just tighten it up, and should solve the problem. also check the power plug to the gauges and make sure its tight. Best I can do.
Dec 27, 2010 | 2001 Nissan Xterra
The backlight is flickering and goes on and off. Any way to fix it or replace it?
Not really a way to fix the problem but I found out that with the photo frame subscription plan, Ceiva will fix or repair the frame for free.
Jan 04, 2010 | Ceiva LF4007 Digital Picture Frame
Sony Vaio Laptop VGN-CR240E LCD screen flickering
Mostly it is the problem of the screen's internal mechanism. Something has got loose and moves here n there when moved. If you can, you replace the malfunctioning parts or consult service centre for it.
Aug 10, 2009 | Sony Computers & Internet
Screen flickers
If light is good and picture flickers, then it is either a bad LCD ribbon cable, or cable not well placed into connector, or a bad LCD display, usually it is the cable.
If picture flickers like light is dimming out and coming back, then it is the LCD lamp, probably in need of replacement.
In some rare case a faulty Video card is causing the problem.
Usually to fix this you need to take apart LCD display and upper laptop plate, to reveal the display cable.
Aug 16, 2008 | HP Pavilion dv1000 Notebook
PANDIGITAL 8.0" Digital Photo Frame (PAN802) Logo
771 people viewed this question
Top PANDIGITAL Photography Experts
LP
Bill Eager
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
