Question about iLO XM-MP3-CD Car Stereo
My in dash dvd player doesn't play cd's or dvd's. I don't know y but there is picture and no audio, and for some odd reason a static sound comes on instead of the audio - please help. I own a jensen vm9410.
  • 578 Answers
Check the ground and if you still have that you audio out put on you deck is bad
Posted on Jun 26, 2009
2003 Chrysler Town & Country DVD Player doesn't output picture to screen, audio on right side only.
The cost to repair it will cost you more then to just buy a used one from a auto wrecker.
Oct 19, 2012 | 2003 Chrysler Town & Country
When I try to use my dvd player I put a disc in it says loading them it comes up and says bad disc, it will also do this if there is no disc inserted into it, can you help me? I don't know the model #...
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Koss KS4110 DVD Player
Cd player has no audio
Odds are you car has a factory amplifier, and you used the power antenna wire to turn it on. Swap your blue wires, and you should be fine.
Aug 10, 2009 | JVC KD-AVX1 Car DVD Player
Burning DVD from Windows movie maker and audio is funky!
after copleting save it in u r system as .dat format.
then use nero n select make video dvd
ur's kishore
for more help catch me on +919985064600
+919963674002
friends_kishore@yahoo.co.in
Feb 10, 2009 | Roxio Easy CD & DVD Burning
Play my mp3 in 2006 Nissan Quest?
I was told the in dash radio unit will not play mp3's. as far as the dvd player, if you have the entertainment system i can't say. I do have two solutions for you.
1) the in dash cd player (mine is a 6 disc cd player) will not play mp3's at 128 bit compression, but for some reason or another I burnt an mp3 disc using the 256 bit compression, still smaller than the standard mp3 comparable cd quality, and unknowingly tried it in the cd player. The nissan quest played it. So it sounds as if the cd player is picky about how low quality of an mp3. 128 is a common reasonable quality. However, I was able to squeeze about 15 tracks on a 256 bit mp3 disc.
2) the in car dvd unit. If your unit is of the standard type, under the seat or mounted elswhere in the car, you could replace it. Dvd players sell for around $125.00+ and will play everything under the sun. reconnecting is not the biggest challenge neither.
& 3) You could purchase an additional hardwired device which allows you to plug in any audio device and play the sound through the Nissans sound system. The device into plugs directly into your wiring loom behind your factory radio. The best part is that the nissan system is already set up to receive this device. It will play through the sat1 or sat2 buttons. I searched and purchased the device online.
i had installed that before learning of the mp3 deal.
well good luck.
Sincerely, Flash
Jan 19, 2009 | 2006 Nissan Quest
I use a tascam dm24. i am getting drop out when my music is playing. i also get a static sound sometimes after drop out.
ok question when you play music is off cd or comp. or mp3 player
reason i ask is cause some cd formats and songs come with the distortion on them the manufacture does not see this cause mass production in cd's
turn onto a receiver fm tuner if static is still there power failure is common in the power house inside receiver these require maintenance and probably new power house conductor
dust in the system can create static also hair and dust are magnatized this can distort the sound quality professional cleaning of system is probably needed in this case
May 12, 2008 | Audio Players & Recorders
No picture, only sounds when playing DVD
The issue might be that you could be missing some codes to play the dvds.
First i want to uninstall all the codecs from the control panel - add/remove programs.
Then download the latest vesion of klite codec pack with the player.
The link is :
http://ftp.freenet.de/pub/filepilot/windows/multimedia/video/k-lite_codec_pack/klcodec390f.exe
Install this by selecting "lots of stuff" with the player.
Then play your DVD, it will work fine.
Good Luck.
Live, Love, Laugh.
May 08, 2008 | Haier PDVD10 Portable DVD Player
Pioneer MT2000 Stereo M-error message for CD
it might be new cd's they have come long ways older players are not excepting newer cd's for some odd reason maken you go out and up grade your players
(thats just wrong)
but try this put in one of your older cd's if it plays that then its the new format cd's that just came out
i havent heard of conversioned cd's dvd's yet but everything bought in 2007 new or older than 2007 is being outsourced to new source cd's dvd's
my opinion if old cd's work then your going to have to upgrade to better system
May 07, 2008 | Audio Players & Recorders
No audio
FM station 88.1 or similar. Set radio to scan while dvd is playing. When the correct frequency is reached, you'll hear sound.
May 06, 2007 | Blaupunkt DVD-ME2 Car DVD Player
iLO XM-MP3-CD Car Stereo Logo
323 people viewed this question
Top iLO Car Audio & Video Experts
xxxxxx xxx
Libran Moreno
Steve Sweetleaf
Steve Sweetleaf
Are you an iLO Car Audio and Video Expert? Answer questions, earn points and help others
