Question about Sharp AL-1655CS Copier
Sharp AL 1655CS Grayscale Copier prints with black lines
The lines are on the sides and in the middle
i cleaned the inside and also the toner cartridge but the lines keep on pritning
what should i do?
  • 143 Answers
Lines on copies can come from the optict area, charge grid and comb or the fusing roller. Stop the copy halfway through the cycle and see where the line starts to appear. If you see it as much as you do the rest of the print, it is either optical or in the drum charge unit.
Posted on Jun 26, 2009
My copier is printing large black lines on one side of paper
CHECK THE WAST TONER CASE, IF IS NOT FULL,CLEAN THE MIRRORS AND THE LENS IF THE PROBLEM PERSIST CHANGE THE CLEANINING BLADE.
Sep 09, 2010 | Sharp AL-1457 Black and White Copier
Which toner cartridge do I need? Where can I buy one?
The Sharp AL1631 takes a Sharp AL 100TD cartridge (hi-yield), or a Sharp AL 110TD cartridge (standard yield). IBS still has them, there phone number is 800-8810226.
Mar 12, 2010 | Sharp AL 1631 Copier
My Sharp AL-1655CS copier has new drum and toner. Leaves blank banding lines verticaly down the page in at least three areas.
This is a good one you may need to get it serviced.
The toner is held to the drum by static which rolls the toner onto the paper and seals the deal you may have a bunk drum, Validate your warranty and check for a service center.
Oct 19, 2009 | Sharp AL-1655CS Laser Printer
Copier says ready to print. when button is
you will require to check several things like ink toners alignments and settings try resetting the wholesystem. top of all there may be some software problem try reinstalling the softwares if it is connected to computer
Jul 21, 2009 | Sharp AL-1655CS Laser Printer
LOUD GRINDING NOISE
The black dust is toner. Be carful as it is carcenagenic (dont get it on your skin) you will need to dispose of the leaking toner cartridge and get a new one. also you will need to clean the printer very carfully to get rid of the spilt toner. A combination of spray duster and a toner hoover are the best way. do not use a normal hoover as you will kill it.
It is always possible that you have done serious damage to the printer using a non standard toner cartridge. I would recomend getting a qualified person to give the printer a good service.
Jun 03, 2009 | Sharp AL-1655CS Laser Printer
Grinding noise at startup and printing, AL-1655CS
is there some paper or something inside
just a thought
Feb 04, 2009 | Sharp AL-1655CS Copier
Printing line on the right side of paper
I am unsure of one thing in this post, Is the new toner cartridge still spilling out ink and developer?
Now, from there, you need to get a vacuum with a crevice tool and vacuum the inside of the machine very well. There are ridges and stablizer brackets formed into the frame that the toner and developer fall into and sift out onto the paper.
If your cartridge is still dumping the developer and ink from the same end, I highly suspect the machine is not level from front to back and as the machine runs the toner and developer are moving to that end of the cartridge. Once that happens that cartridge will spill the contents out into the machine.
A thorough cleaning is needed, and even at that, it may take some time for all of the contamination to run itself out. It is difficult to remove all of it.
Mar 25, 2008 | Sharp AL-1655CS Copier
NEW SHART COPIER- NOT PRINTING DOWN THE MIDDLE OF SHEET
1. Check the toner cartridge and be sure nothing is blocking the ink flow.
2. The drum cartrudge may also have something on it blocking the laser light from getting to it.
3. There may be something in the laser window blocking part of the light path.
4 Something in the scanner blocking the image.
5. A defective scanner, yes even if new.
Feb 22, 2008 | Sharp AL-1655CS Laser Printer
Single line printing in copy mode
CLEAN OFF GLASS ON TOP WITH WINDEX THEN RETRY COPIER
Jan 17, 2008 | Sharp AL-1655CS Laser Printer
Sharp AL-1655CS Copier Logo
175 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
