Question about Whirlpool 25.2 cu. ft. Side-by-Side Refrigerator ED25PQXF
ED25PQ quit making ice. Water dispenser still working
ED25PQ quit making ice. Water dispenser in door in still working.
  • Whirlpool Master
  • 1,606 Answers
Pour about 1/2 cup of water into icemaker . If it harvests(dumps) then problem is the water valve.....if not , then icemaker is the problem .
Posted on Jul 06, 2009
We have a side by side Whirpool Ref Model #ED25PQ. It makes ice and despense ice inside the ref into the ice tray. Our problem is with the door closed we are unble to get ice thru the door into the...
I don't know if this is your problem, but my sister had this problem before. When I checked the area, it was clogged with dried soda. The kids allowed it to splash up when ice dropped into the glass. The sugary drinks will dry sticky and not allow the dispenser to dispense. I used very hot soapy water several times to melt the sticky buildup. Her fridge has been working every since. Good luck, it this is your solution
Aug 18, 2013 | Whirlpool ED5FTGX Side by Side...
Ice maker doesn't make ice anymore. The water works and dispenser levers on the door work for both ice (use store bought ice dumped into tray) and water. I replaced the filter after it quit making ice. Not...
you've already done the first thing i suggest, and that is to change the water filter. But if you still cant get ice made, you have a problem with either your ice maker or your water valve, or an electrical issue in the ice maker system.
Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The ice maker will not quit dispensing ice and it no longer cools
For now unplug the pin plug at lower freezer door hinge and disable the dispenser control board until we see if the keyboard or the dispenser board is at fault. Sea Breeze
Feb 22, 2010 | GE GSL25JFPBS Side by Side Refrigerator
WATER DOES NOT DISPENSE FROM DOOR
Sounds like the water solenoid valve poppet is sticking in the closed position. You will need to replace the assembly. It is located behind the fridge at the lower corner.
Jun 18, 2009 | Whirlpool ED5SHAXM Side by Side...
Ice and water don't work
This could be several reasons, water valve on back not working, thermostat in ice tray not working, heating element below ice maker not working, we just need to start with the dual water valve on back first. The side that feeds the ice maker needs the solenoid checked. I am ready to help you solve this, Let me know, Thanks, Sea Breeze
Apr 16, 2009 | Refrigerators
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Refrigerator/Freezer Model # ED25PQ
Hi!!!Hi!!! change your ice maker control module on your icemaker its letting to much water it show here its the one with with the white round wheel..change it and all should be fine..googd luck..
Jan 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side refrigerator, model # ED25PQ
Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
Nov 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
384 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
