Question about HP LaserJet 1200 Printer
Ink not set
When i print out the ink comes off like dust as though it hasnt set properly
  • 417 Answers
Re: ink not set
At the back of the machine open the door and make sure that the green levers are in the up position or if they are there at all.
As these levers apply pressure between the heat and the pressure roller forcing the toner onto the page. If they are there and in the correct position then the likely thing is that the fuser unit will need replacing.
Hope this is of help to you
Thanks J
Posted on Jan 06, 2008
0 characters
3 Points
How do I make a test page for my printer to check color.
You need to clarify :
1. Your printer cannot print color even though it prints color well from a test page;
2. Your printer cannot print color in a test print page.
If it is the first one, then you have to set it properly in Window Print Configuration page of that printer;
If it is the second one, then you have to check whether you have installed the color ink cartridge properly in the printer. If the color ink cartridge is installed properly, try to replace another new color ink cartridge. Finally it is still not work, then you have to bring back to the repair center.
Jan 19, 2013 | Dell V715w All-in-One Wireless InkJet...
How to install a printer?
1. Un packing,removing the seals, cartridge set up, print heads setup, cabling set up, power conditions, power grounding etc ..comes under hard ware set up.
2. Loading the software drivers, configure the IP, sharing, scan setup, fax set up though PC etc comes under software set up..
Depend up on models & functions, technology(Dot matrix,Ink jet,laser jet)the installtion procedure will varies.
Thanks for your direct questioning me, but pl give the model Number to give proper installation procedure to help you better...
Nov 26, 2011 | HP Printers & Copiers
Hi i have an epson stylus c64 and it hasnt been used in quite some time, i tried to print from it and it didnt work so i went and bought all new ink cartridges for it as i thought because it was stilling...
When printers sit for a long time, the ink in the cartridge dry-up as well as the ink in the printer orifices.
Since you replaced with new ink, then safe to assume the ink is dry and clogging the orifices.
You can pay for technician to attempt to clean but new printers are fairly inexpensive. Best bang for the buck would be to purchase a new printer.
Apr 01, 2011 | Printers & Copiers
Just replaced ink cartridge and still says cjeck ink and it will not print
did you get a brand name canon pg40 or pg 50 ink cartridge, i replaced the one at works black cartridge with an eco refilled cartridge and it still showed up empty even though i know it wasn't. its canons way of making sure you buy canon. there are ways around it though. hit menu navigate to "rx settings" hit okay then hit okay on "autoprint rx" make sure it is set to on and hit okay, then make sure "print when no ink" is also set to on and hit okay again. it will now automatically print even if the machine thinks there is little or no ink. cheaper knock off cartridges here we come!
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
I have installed a new black ink cartridge. "Ink is out" comes up when I try to print. It is properly installed and is the second new black ink cartridge this has happened with. The "On" and 'Ink" lights...
I have installed all new cartridges. "Ink is out" comes up when I try to print. It is properly installed and is the second set of ink cartridge this has happened with. The "On" and 'Ink" lights do not stop flashing. The printer does not see the new cartridges.
Jan 04, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Won't print black when set for plain paper
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
May 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
My printer will feed paper, but no ink is printed..
i im  josh in cebu phils.may i help you? Friend the printer that prints and without ink appears even though not run out of supply. the problem is not the ink  but the tank lever that carries the cartridge.there maybe stuck dried ink on it came from previous ink installed that drain on the lever. Solutions: 1. try to remove all the ink and clean the lever with a soft cloth. 2. go to settings and perform the head cleaning and nozzle check. 3. do the printing repeatedly until the ink comes out. thats all friend good luck hope i helped you.
Mar 14, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Non of the inks are working, even though they are all new carts.
so go back to maintenance mode. Make sure all carts are at full level, placed well and are secured. press 7 then 6 then 4 by help of arrow-up and set key. display should be init_all. press start bk-copy. when finished (maintenance) press 7-6-3 then start bk-copy.
leave maintenance after cleaning procedure by pressing 9 then 9. If youre lucky the generic ink hasnt affected the ph. print a test prit. if you cant see any blocks nor signs the ph needs replacement.
anyway: if you use generic ink do mix some glycerol (glycerin alc.) from drugstore: 2ml of 85%-glycerol with 8ml of generic ink. This prevents the ph nozzels from drying out or clogging!
Mar 24, 2008 | Brother DCP-310CN All-In-One InkJet...
Ink not sticking to paper on textweight, possible fuser problem?
Have you properly make setting for media attributes ? plain -normal paper.
Nov 05, 2007 | Xerox DocuColor 12 Printer
HP LaserJet 1200 Printer Logo
35 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
