Question about Tools & Hardware - Others
Electric Sander Looking for a sander to prep my exposed wood areas for exterior house painting
    Problem Solver:
  • 11 Answers
Get a good 5" random orbital sander with hook and loop paper. They are easy to handle while on a ladder.
Posted on Jun 26, 2009
What is the usages of a PALM SANDER?
What an odd question .....
To sand small areas that are otherwise inaccessible to orbital sanders.
Apr 07, 2018 | Tools & Hardware - Others
Can i paint my garage doors?
Clopay's steel garage doors can be painted with any high quality exterior latex paint. Wood garage doors must be painted/stained on all sides prior to installation. Most models are available factory primed. Clopay recommends wood garage doors be re-painted every 1 to 2 years (more frequent refinishing may be required in high moisture areas).
Oct 02, 2014 | Building Materials
How to prep to paint a steel exterior door
Use a sponge sander to send the door and top coated with DTM metal paint it is a water-based product
Aug 10, 2014 | Home
What causes my belt sander to leave black goo on the wood? I keep replacing the sand belt, I do not push the sander into the wood.
Maybe you are burning the wood. If the wood is hard (like oak or maple) and the grit is fine (like 100 or higher) then this can only be avoided by NEVER running it still in one place. Keep the sander moving quickly over the surface. In fact, you should start the sander BEFORE you touch it to the wood, and when you do touch the wood you should be landing it like a little airplane on the runway. As long as you keep the sander oriented with the grain you can move it forward and back as well as side to side. Just keep moving until you lift it off of the wood - this also helps keep the surface flatter. Good luck.
Jul 30, 2012 | Skil 3 in. x 18 in. Belt Sander - 7500
Sander disc no longer "sticks"
Most commercially made disc sanders have replacements pads whether they are hook and loop type or the rubber. If you go to the manufactures web sit and look up your sander, it will usually be listed somewhere. But you might have to call an authorized repair center to find the part number to order.
Jun 07, 2011 | Vacuums
The electric cable has got caught in the sander. How do I unassemble to remove the cable?
Hi Mark,
Hear is an exploded parts diagram for the sander:
http://www.powertoolspares.com/tool/makita/spares-and-accessories-for-9404/9404/spares/
Remove the three screws on the handle cover part 23 to expose the cable connection to the trigger switch.
Apr 28, 2011 | Makita 9404 4'' x 24'' Belt Sander
Hello I have a compressor and my electric orbital sander has finally gone legs up. My question is if I get an air sander primarily for sanding wood is a straight line the best sort to get or are the...
I work in a wood working shop and we use orbitals on everything. You still will still sand with nice even strokes with the grain. It leaves a great finish. They are nice, light, and easy to use! They do use a lot of air though, so make sure your air compressor can handle the one you buy. If you compressor is constantly running you might have to take breaks so you do not burn it up. enjoy!
Apr 11, 2011 | Sander Viking Air Tools Dual Piston...
I have a MS1000 Black and Decker Cyclone round sander..looking for replacement sanding disc
Hello, W/D here.
Most sanding disc types are available at the larger box hardware stores. They are (sometimes) generic or exact replacements.
I use the "Gator" brand on my B7D sander, and the discs work just fine.
Best regards, --W/D--
Feb 23, 2011 | Black & Decker Black And Decker Cyclone 4...
Clarke FM1700 buffer-sander, problems with using it
what is the condition of the felt pad on the driver?? The sander should not be that hard, usually you need to lift up or slightly bear down to get the machine to move left or right. Are there any exposed nails in the area you are sanding and check the grit for the sanding conditions
Aug 23, 2009 | Clarke Floor Sander Floor Sander Orbital...
Tools & Hardware - Others Logo
76 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
