Question about Maytag MSD2756G Side by Side Refrigerator
I have a puddle forming on the freezer side of the maytag msd2756gew side by side refrigerator. It seems i have a leak. what could be leaking and how do i fix it?
  • Maytag Master
  • 4,655 Answers
Your Ice Maker could be leaking or the defrost drain behind the back freezer wall could be blocked with ice or another source of blockage leading down to the pan below your refrigerator where the water is heated by the evaporator fan and replaced back into the air inside your home. You will need to unplug the power before going into the back of your freezer. Let me know if you would like help. Sea Breeze
Posted on Jun 26, 2009
I have an RSW2400 which has had a similar problem that is now occuring again. The problem is probably a clogged drain line from the freezer to the catch pan under the unit. A puddle forms when the defrost cycle runs, usually about twice a day in warmer weather. It seems that there must be a design flaw since I see this problem on so many boards.
Posted on Jul 07, 2009
Msd2656ge repair
Mosty likely you are having the symptoms of a defrost drain blockage. Here is more=> Leaking Refrigerators I am here should you have questions, Sea Breeze
Aug 21, 2013 | Maytag MSD2656G Side by Side Refrigerator
I have a Maytag MSD2556AE Side by Side Refrigerator/Freezer. I keep getting a puddle of ice in my freezer and water leaks out of the freezer onto the floor. All this happens in spite of the water line to...
Sounds like you have a frozen drain line. I would unplug the unit at let the drain line thaw. This would be the easiest way to rectify the issue. Leave both doors open for 24 hrs. Hope this helps _MJ_
Jul 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
MZD2766 GE - A puddle of ice forms at the bottom of the freezer
Sounds like the defrost drain is cloged. There is a hole at the bottom of the freezer behind the back wall. if this is cloged then the water that is suppost to drain there will overflow and freez.
Jul 04, 2010 | Maytag MZD2766GES Side by Side...
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag Plus MSD2556AEW - frozen puddle on freezer floor
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water leakage in and below freezer on Maytag MFD2560HES
you have a clogged defrost drain, or your ice maker (if so equipped is leaking. clogged drain can be remedied removeig drawer , andmelting ice build up behind rear panel of refrig, you see an aluminum trough that the water drips down,using a hair dryer melt all thatice out of the way to clear the drain tube(i use a steam machine i purchased from infomercial works extremly well
Feb 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag MSD2756G Side by Side Refrigerator Logo
536 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
