Question about Toshiba Televison & Video
9 year old Toshiba TV. The picture is totally
9 year old Toshiba TV. The picture is totally black with a stripe of light through the middle.
  • 10,594 Answers
Symptom shows TV got problem in vertical out deflection section, please check and replace vertical output IC and nearby electrolytic capacitors.
Posted on Jun 25, 2009
There is a vertical black line about 25% of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 28, 2015 | Samsung PN51F5300AF 51" 1080p Plasma TV -...
The picture seems to be getting darker. Its not as bright and sharp as it used to be. Its about 9 years old but has not been used very much. Might it need a new bulb or something? 57HX81 Proj TV Color...
simple: remove back cover and locate the three large black lens you will see top and dead center, clean them with either a lens cloth or a paper towel with glass cleaner----they are the light source for your picture and should be cleaned once a year---as they get dusty the picture gets darker and duller looking.\\
SD TECH
Apr 12, 2011 | Toshiba 57H81 57" Rear Projection...
Turned on my TV today to find a 5" horizontal stripe across the middle of my screen. I can view the picture through the stripe but the picture brightness on the top 1/3 and bottom 1/3 of the screen is much...
This sounds like an impact injury to the screen itself. It is likely that something may have hit the screen or if the set is old, the part inside may be starting to go.
Hope this helps
Nov 27, 2009 | Sylvania LC320SS8 32 in. LCD Television
No picture; black screen; only red light blinking.
take to a service station i think just changing the displsy IC would do . but check in service centre
Jun 19, 2009 | Toshiba CZ32V61 32" TV
No picture on my Toshiba 42HP66 plasma tv.
I too have this problem with no help from hh Gregg, where I bought the tv, and no help from Toshiba. I resorted to calling the BBB and complaining about the defective workmanship. I took the tv, which is less than 2 years old, apart and found the y-sus board, behind the y-sus board is a foam rubber spacer to seperate the circut board from the backside of the screen. I think this pad is designed to prevent heat buildup in the y-sus board. The pad itself is held on by glue and that glue melted causing the y-sus board to short out. I noticed this after finding a tacky substance behind the board. The heat from the plasma screen melted this and also the pad itself. Toshiba claims no resposibility because the tv was out of warranty. Thanks Toshiba.
Jan 22, 2009 | Televison & Video
We own a Toshiba Regza 42" direct view LCD TV. We have owned this since last November (bought as a Christmas gift). This TV was working great until last night (7/7). Powered it on and for a split...
Unfortunately there might no be a fix for this type of failure unless the LCD is open and perform a few measurements in the circuitry. Since the TV is less then a year old, I would suggest to contact the vendor or manufacturer to have it repair under warranty, most electronics devices carry one year warranty.
Let me know if you require further assistance.
Jul 08, 2008 | Televison & Video
Toshiba DLP 50HM66
The bulbs for this TV seem to go about every couple years. The price has dropped down a bit. I have found it for 118.00.
Feb 17, 2008 | Toshiba 50HM66 52" Television
Toshiba tv
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
cost for DYI is about 60 bucks
Feb 12, 2008 | Toshiba 42H81 42" Rear Projection...
2-inch picture stripe in middle of screen.
deight, your set is going into total vertical collapse, either the vertical IC is failing or some support component to the vertical circuit is failing, should not be an expensive repair, hope this helps, BMW Rider
Dec 12, 2007 | Sylvania 6419TA 19" TV
Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Nov 05, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Televison & Video Logo
209 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
