Seems to have hidden interior clips or retainers of some sort - about 3-inches from the top on both left and right sides.
SOURCE: I have an older unit need to know what the top knob does
One of the knobs controls fan speeds, cooling speeds and an off position. Center knob controls temperature and bottom knob more than likely controls air exchange. As for the front cover it would depend on the units age as to if it would be available.
SOURCE: How do I remove the front panel to clean the coils
front panel has one phillips screw in it. remove the air filter and you will see it. Once you remove the screw, grasp the lower front sides of the cover, where the plastic meets the metal, and gently pry it outwards and towards you. there are plastic clips that hold the cover in place. One on each lower side and three on top.
SOURCE: model a6q10f2a beeps 2 times when plugged in, and
Pull the unit from the wall and it`s shell,check the fan to see if it is turning ok by hand,if there is any restriction,it will blow the control board,the circuit board behind the controls,clean the unit while you have it out,if the fan is stiff,and does not turn,this could be the problem,and if so,the circuit board is most likely shot.Also,the circuit board is most likely shot anyway,even if the fan is fine,there is a lot of problems with fedders and other brands,and the circuit boards,they dont last too long.
